#778387 by ccarmock
13 May 2011, 23:33
I am currently booked in a B class ticket in Economy - can that be used to upgrade to PE with FC miles??
Recently a member of the UK call centre team told me Y B & L fares can use miles to upgrade. However when a colleage from work was travelling with me I wanted to use my miles to upgrade her to PE, she was holding a B ticket - intially we were told yes and then told no.
Given the confusion the check in agent did it anyway.
#778389 by northernhenry
14 May 2011, 00:18
ccarmock wrote:I am currently booked in a B class ticket in Economy - can that be used to upgrade to PE with FC miles??
There needs to be reward seat availability in PE...
L should be cheapest, but be warned check against cheapest PE fare in sale
Log into flying club go to Spend miles-upgrade-choose fare code in drop down box
Remember to add PE tax/surcharge difference....
Dummy book a miles reward seat on the flight you want to see if there is availability (ie a seat that can be used to upgrade into)
NH
#778390 by tontybear
14 May 2011, 00:28
Yes - a 'B' is upgradable using miles see the fare code page
BTW you dont need to be logged into FC to use the upgrade search option and as the 'B' fare is listed as an option there it stands that it is upgradable !
Looks like someone at VS needs a refresher !
#778397 by northernhenry
14 May 2011, 09:29
tontybear wrote:BTW you dont need to be logged into FC to use the upgrade search option and as the 'B' fare is listed as an option there it stands that it is upgradable !
Splitting hairs Mr Bear :D
It would make sense to be logged in, as you'll need to search for U availability |:) :D
NH
#778406 by northernhenry
14 May 2011, 11:50
ccarmock wrote:Thansk tfor this - so I am ok on a B ticket provided upgrade availability is there.
What about a Y or L? in the fare codes section the links for those seem broken
Are you looking here ?
And remember to have the lowest fare tab ticked if looking for Economy fare..
Then have the spend miles tab ticked in PE for upgrade availability - you WILL need to be logged in for this part.. |:)
#778413 by tontybear
14 May 2011, 13:42
yes Y and L are upgradable too - again as long as there is availabilty.
If you are looking on the v-flyer farecode table then you may need to clear cookies as there have been some problems in the past with these links.
Users browsing this forum: Google [Bot] and 180 guests
