#781585 by jcnev
08 Jun 2011, 08:57
Seat map for 9th June is back online and I have been allocated 75H. Emergency Exit in the bubble. I always thought these were only given out at the airport?
Does anybody have any experience of this seat. Is it narrower because the TV is in the armrest? And because of this is the TV much lower down therefore will I end with a crook neck.
#781588 by Neil
08 Jun 2011, 09:08
The only reason your seat map is back is because the flight is tomorrow and will need to go live for OLCI. The flights in the future do still not have the seat map available yet.
It is slightly narrower, but not a big difference with the PE seat being wide anyway.
The tv is on a moveable arm, so you will be able to put it in a position that suits you.
#781656 by Silver Fox
08 Jun 2011, 16:24
jcnev wrote:Seat map for 9th June is back online and I have been allocated 75H. Emergency Exit in the bubble. I always thought these were only given out at the airport?
Out of curiousity, was your seat in the bubble before or had you not pre-assigned one?
Users browsing this forum: Google [Bot] and 166 guests
