#783229 by tontybear
21 Jun 2011, 09:38
Which ones ? From a flight ? Credit card spend ! Online shopping via VS website ? Transfer from a partner programme ?
Thery all have different posting timelines.
A few more details would help!!!
#783230 by libznlmfp
21 Jun 2011, 09:44
Due to fly May 2012 have made an airmiles acct and it says "this booking will give you so many miles and 6 tier points" but there not showing in my acct?? Do they only show once you've flown??
#783231 by Hamster
21 Jun 2011, 09:48
Yes they are only posted into your account once you have physically flown on the flight.
#783232 by libznlmfp
21 Jun 2011, 09:51
Hamster wrote:Yes they are only posted into your account once you have physically flown on the flight.
Thank you,am new to this :|
#783238 by Martin
21 Jun 2011, 11:03
Libz
I can see you are new to the signature line as well. If you go back to the edit signature in the UCP area and swap the text you have currently with the format below, you should get the desired effect. You need to replace the yyyy/mm/dd and put in your date in the format 2012/05/04 to make it work correctly.
Good luck.
Martin
[event=yyyy/mm/dd]Orlando Florida[/event]
..and you should get:
Users browsing this forum: Google [Bot] and 177 guests
