tontybear wrote:Freckles wrote:I thought all aeroplanes had to be within an hour and a half of land at all times for emergency reasons with the only exception being the Sydney to South America route. ?|
There are certain limits but 2 hours comes to mind for some plane types and 3 for multi (3+) engined craft but it is nothing to do with flying over water but time to a diversion airport so it applies to flying over land too.
ETOPS/LROPS start at 75 mintues and work up from there.
clarkeysntfc wrote:ETOPS only applies to twin engined aircraft. 4 engined aircraft like the 747 aren't subject to the same stringent regulations when it comes to maintaining a close distance to land.
Nope, ETOPS applied to twins, ETOPS has since been replaced by LROPS (Long Range Operational Performance Standards) LROPS kept everything that ETOPS had and added provisions for aircraft with 3 or more engines.
You then also have non LROPS flights, they are covered by the "over water" rules.
mcmbenjamin wrote:
You will be fine. Remember, four engines for the long haul was a Virgin motto for a while.
Actually it was an Airbus motto.
