#799911 by Smid
15 Jan 2012, 15:53
Is this ever a likelyhood in VS? I know the Nova/Odessey are ancient (and I suspect VHS or beta based), and looped so pointless for this sort of thing, but is there any particular reason why Virgin can't or won't do this. But with JAM or V-Port, is this likely to happen..
It would make my flights so much better. Even the 10 minutes taxi from landing to the gate might be worth sitting to see the end of something... Last off the plane?
#799915 by clarkeysntfc
15 Jan 2012, 16:12
I believe this can't be done because the CAA (UK aviation regulator) prohibits it.
My opinion is that no IFE on the ground is a good thing. I wouldn't want to be evacuating an aircraft with people getting tangled in headphone wires etc.
What I would say is that both BA and VS could probably switch it on a lot sooner and off a lot later than they currently do.
#799928 by flyerdavid
15 Jan 2012, 17:41
Agreed, could easily be started sooner.
I once took a My Travel Airways (MYT) flight to BGI and they kept the outside cameras on for take off and landing (but no IFE) - was great to see the landing from that perspective. Though I think the CAA don't allow this and MYT were registered overseas I believe...
#799937 by voyagerweb
15 Jan 2012, 18:32
Thomas Cook still do this to the day and they are reg in the UK.
#799948 by Smid
15 Jan 2012, 20:54
I thought someone on a Air New Zealand flight had commented about this... On a LAX to LHR flight.... So I assumed that it wasn't the UK regulations...
#799964 by GlasgowBoy
15 Jan 2012, 22:27
I've seen Emirates & Icelandair flights arrive into GLA with the IFE still on, and films still playing after the pax have disembarked. Same with departing: IFE is switched on/reset just before the pax board.
#799967 by Smid
15 Jan 2012, 23:04
GlasgowBoy wrote:I've seen Emirates & Icelandair flights arrive into GLA with the IFE still on, and films still playing after the pax have disembarked. Same with departing: IFE is switched on/reset just before the pax board.
Was that looped or on demand?
So, is it technical problems with the VS or regulatory, or a combination of both?
#799968 by honey lamb
15 Jan 2012, 23:20
Emirates and Icelandair are not governed by CAA as they are registered elsewhere.
It isn't a technical problem with VS. I recall one flight several years ago from MCO where the IFE, albeit just the map was on when we got on the plane and remained on after landing. The other day when flying in to Dubai there was a promotional video of all the VS destinations being shown while we were landing and today, after they had shown the Change for Children video, someone had forgotten to switch the IFE off and so we had the map showing us doing loops of LHR until someone realised it and flicked the switch. Boo! Hiss!
#799969 by glennh
15 Jan 2012, 23:28
Air France A380 had promo videos and outside cameras playing during take off and landing on their LHR to CDG flights last year. Terminal 4 Tarmac not that exciting but there was some impressive lightning storm footage after take off :-)
I've been on VS flights where they turn the IFE off about 80 mins before landing -far too long.
#800042 by Spill
16 Jan 2012, 19:03
We once flew into mco on airtours many years ago. They had a camera that looked out front from underneath the ac. We were able to see the guy guiding the plane onto stand. Once the ac came to a stand still, he turned around and bent over to put something down or something. He was not the slimmest, and we got an eyeful of his huge "builder's bum". The plane went nuts with cheers, laughter and clapping.
#800218 by ccarmock
17 Jan 2012, 23:43
I ws on an SAA A346 that had the tail mounted camera - it was on throughout including take off & landing. fascinating to watch.
Is this standard on all A346's? If so a shame VS don't feed it through to the IFE
#800220 by mitchja
17 Jan 2012, 23:49
As already mentioned this is a CAA regulation thing. Any carrier using UK registered aircraft must comply with these CAA regulations.
VS 346's do have the same tail mounted external cameras (along with a belly cam as well) but these are for flight-deck use only.
#800223 by scally
18 Jan 2012, 00:03
I understand it's not so much the country of registration, but that the airlines have to get re-certified for operating IFE gate to gate, as their procedures will change.
Other airlines (Air Canada) place restrictions, such as you can use your IFE but only with earbuds, not headphones that have a band that go over the head, as then I guess the band may fall over your head and prevent you from leaving the aircraft.
Restrictions also apply to J pax as their screens are on stalks, similar to the UCS, so it's Y pax only.
VS could go for gate-to-gate IFE but it would cost them quite a bit to get certified.
But that's just my understanding... can't remember where I read that now.
#800312 by Tinkerbelle
18 Jan 2012, 22:04
mitchja wrote:VS 346's do have the same tail mounted external cameras (along with a belly cam as well) but these are for flight-deck use only.
And here is the view from the camera...
340-600 Tailcam
#800333 by honey lamb
18 Jan 2012, 23:25
WOW!! That is sooooo exciting - NOT!! :o)
Users browsing this forum: Google [Bot], marklife and 193 guests
