#2728 by Vegascrazy
28 Sep 2004, 00:19
As mentioned in my trip report I was going to look at fares for flying into LAX and returning from LAS, as we like a spell in Palm Springs followed by a few days in Vegas & it saves the drive back to LAX on the last day, plus we live close to LGW. I just obtained quotes on VS web site for outbound on Fri 25th March '05 & return on Sun 3rd April '05. Results are follows:-
In & out of LAX: £4,406.60 (for "Upper Class lowest")
In to LAX out of LAS: £13,179 (again for "Upper Class lowest")
I'm amazed that returning from LAS makes the whole fare three times more expensive!! Any ideas?
#42051 by mike-smashing
28 Sep 2004, 00:39
Could be the following:
* Little or no availability out of LAS vs. LAX
* VS don't allow "open jaws" on your ticket/route, so it looks like two full-blown J singles back-to-back
Those are the most likely reasons.
As for me, I'd prefer to fly the cheaper fare, get the better service (bigger bar, ifbt), and have a shower in Revivals when I get back! ;)
#42052 by pegitt
28 Sep 2004, 00:52
I have done flight's to both LAX and SFO ret LAS for the past 2 years one thing i have found is if you call FC they will help you more than a PC can, When we did SFO ret LAS Apr this year we pay'd £845pp in PE, our flight's for next year out JFK (PE) ret LAS (UC) come out at £1895pp + $504 A west JFK-LAS 1st class but we are yet to book them.
I can't see why it would cost an extra £8,800 i would have thought around £400 on top if that, Yes they are the only airline to fly LON-LAS-LON direct but i cant see why that would put the price up that much.
Phil
#42106 by Richard28
28 Sep 2004, 18:53
I normally fly via LAX or SFO to maintain my gambling habit [:p]
Doing some research myself the last few days, and you can get a CO codeshare from LGW via MCO and IAH for £1798 return per person.
that should be Upper Class Suite on the VS codeshare, and first class on the 4 x CO flights.
a bit of a pain with the stop overs, and not so many tier points earned, but this works out quite a bit cheaper!
tempting!
Rich
#42134 by Vegascrazy
28 Sep 2004, 23:31
Thanks for that Richard. Re the CO codeshare, how do I set about getting these quotes? I went on to continental.com (the UK site) and plugged in the dates but it only returned CO operated flights, no sign of any VS operated ones?
#42138 by Richard28
29 Sep 2004, 00:18
Hi Vegascrazy, it's a bit tricky - but here goes:
go to http://www.expedia.co.uk
select the flights tab, and select "multiple destinations"
select:
flight 1 LGW-MCO morning (leaving date)
flight 2 MCO-LAS evening (same leaving date)
flight 3 LAS-MCO morning (return date)
flight 4 MCO-LGW evening (same return date)
select business class
and search!
You may need to play around with dates, and make sure you have a saturday night stay
this fare for example is currently showing outbound 19th May, inbound 22nd May, outbound on VS27, inbound on VS28, showing as Z class tickets.
Incidentally this trick can also be used to get cheaper flights via LAX/SFO and selecting the HP flights you want rather than the "official" VS codeshare flights - the same actual flights come out cheaper!
Hope this helps - let me know if my description above needs any further explanation :D
Rich.
#42145 by pegitt
29 Sep 2004, 02:37
ok just book'd our flights LHR-JFK (PE) Ret LAS HP (1st class) to SFO then SFO-LON (PE UG to UC) this came to £1003.80p pp + 20,000 FC points to UG.
It came out £300pp cheaper than LON-JFK ret LAS-LON why i dont know.
The JFK-LAS flight is with DL in 1st and that came to £205pp i thought that was a bargin.
HTH
Phil
#42193 by buns
29 Sep 2004, 22:24
Phil
quote:ok just book'd our flights LHR-JFK (PE) Ret LAS HP (1st class) to SFO then SFO-LON (PE UG to UC) this came to £1003.80p pp + 20,000 FC points to UG.
You're not setting up your own version of a TP run are you?;);)
Actually looks a good trip at value for money prices[8D]
all the best
Buns
#42202 by pegitt
30 Sep 2004, 01:37
quote:Originally posted by buns4vs
Phil
all the best
Buns
Well you could call it a mini one, But every little helps:)
Phil
