#803934 by Bill S
27 Feb 2012, 19:34
David wrote::D "futuristic bar"
The closest guess should get a prize :P
David ):
LGW fleet:
Bar at the front where 6AK are at present.
New narrower UCS with smaller angle then allows the 1+1 to be replaced with 1-1-1 and 1-2-1 where the current bar is located ):
#803962 by tontybear
28 Feb 2012, 01:33
hmmmm I can see some conversations going like this
CC- 'whisper whisper whisper'
Pax - 'Speak up please. I can't hear you.'
#803966 by Jacki
28 Feb 2012, 04:12
Sorry Tonty, did you say something? :D
#803979 by northernhenry
28 Feb 2012, 11:15
Also note quote for "Upper Class Dream Suite"... :?
Ssshhh!
:D
Last edited by northernhenry on 24 Jun 2015, 22:34, edited 2 times in total. Reason: threads merged to keep all UCDS discussions in one place.
#804012 by honey lamb
28 Feb 2012, 16:36
Darren Wheeler wrote:Trouble with whispering, will it be heard over the higher pitched sounds and won't work with the hearing-impaired. Unless it's "would you like another G&T." ):
Naughty! v( :o)
#804014 by Guest
28 Feb 2012, 16:55
Interesting quote on V-Travelled from a VS press release;
http://blog.vtravelled.com/virgin-atlan ... t-service/
Note the part that says it will be the 'biggest and longest' in the sky; are we to infer from that it will outmatch the J offerings from the likes of SQ (which I think is a horrid seat anyway) and Cathay...and if so, how have they managed to shoehorn so many seats into the A333 cabin?
Or is this another piece of VS blah-speak, and we'll discover they are comparing the new UCDS with J class products of quite a while back, or only from certain 'selected' carriers....
#804031 by Pete
28 Feb 2012, 19:39
The seats can't be that much bigger. Given the layout, there isn't physical space for a much bigger seat. I've used the representational layout on virginatlantic.com to create a to-scale version on V-Flyer, and what that tells me is they clearly need to increase the angle of the herringbone a bit to make it fit 4-abreast, but there's not a whole lot of extra room in that A section to lengthen the suites much. I'm also not sure how they'd be able to widen those seats, given the number they are putting in the cabin.
#804041 by preiffer
28 Feb 2012, 20:08
4 abreast, AND "longest in the sky"...? Really?
CX have an 82" fully flat bed, with an extra extension which increases the width by another 6.5" too. All in business class, not first.
So, given this is a "revamp" (I'm guessing a reposition of the top and tail elements of the suite, to extend...?) I'm looking forward to seeing how that claim works in an aircraft that's squeezed 4 seats in the width that other airlines with exactly the same layout (i.e.: AC) can only fit 3...
#804042 by slinky09
28 Feb 2012, 20:11
Pete wrote:I'm also not sure how they'd be able to widen those seats, given the number they are putting in the cabin.
Perhaps this.
Bet you didn't know there was a buk beds blog!
#804045 by preiffer
28 Feb 2012, 20:24
Interestingly, SQ's First Suites on the A380 only offer a bed which is 27" x 78" as it's stand-alone (theoretically). So, their J cabin has a wider bed mode.
If this isn't the usual VS marketing BS (which, sadly, I believe it to be) it'll be a hell of a product if they can beat the 34" width of SQ's J and 82" length of CX's...
#804072 by pjh
28 Feb 2012, 22:32
Mmmm...looking at this I'm thinking how glad I am that they haven't decided to revamp UCS on the LGW fleet.
#804105 by northernhenry
29 Feb 2012, 17:20
ASWinters744 wrote:Interesting quote on V-Travelled from a VS press release;
Just looked at that link again and it mentions the "largest" not the "biggest & longest", has it been "amended"... :?
IMHO, as always, a lot of noise from VS over what is likely to turn out to be a new mattress and seat covering, a redesigned reading light/ new JAM system and some purple underseat mood lighting/ boob glass holder..
Carefully planned media drip feeding building up to a huge fanfare and underwhelming change to current product..I'm not holding my breath for anything decidely different, although some key improvements will be greatly received.
Users browsing this forum: No registered users and 172 guests
