#806833 by Rotty
03 Apr 2012, 23:08
Hi
We have 2 economy seats booked, as they were reward flights using miles from each account we had to make 2 seperate bookings, we had our normal seats selected together but then paid the upgrade for extra legroom seats ( the £30 ones not exit ones ) so we cannot now select seats in advance
does anyone know what the best way to get 2 seats together would be ? is there a way to do this when checking in with OLCI ?
Thanks in advance :)
#806840 by mpb91
04 Apr 2012, 00:23
Hi Rotty,
I wouldn't overly panic. There is a possibility that you will be seated separately. However, the reservations team have an allocation and the airport has an allocation so I personally would check yourselves in on-line as normal and if you find you are seated separately just get to the airport nice and early before others purchase them on the day and I am sure you will get your two seats together.
Hope this helps.
Krgds.
#806874 by Neil
04 Apr 2012, 14:41
Rotty wrote:Thanks for the replies, with OCLI is there any way I can check both bookings in together ?
Yes, once you have put your details in, it will give you the option to add other passengers from different booking references.
Users browsing this forum: No registered users and 188 guests
