Where are the trays in PE located ? I seem to think that they are in the arms but can't be sure. Reason i ask, I'm not the slimmest person around and keep thinking that it won't accommodate me. ii) I've used trays from arm rests before and everything was ok as they moved out towards the seat in front for a little bit more room. Is this the case with VA ?
The trays are in the arm rest, which is the case on all VS PE cabins's regardless of a/c type. With the seat width being 38" it would be a struggle to get them close enough if on the seat in front.
Neil - I think you meant pitch not width
I think seats with 38" width would be very popular indeed but probbaly not very practical !
tontybear wrote:Neil - I think you meant pitch not width
21" is usually enough
To the OP, from what I remember, yes they do slide a bit but the weight of the tray might cause it to list a bit if the armrest isn't supporting it
Users browsing this forum: No registered users and 174 guests
