#812774 by wsussex
04 Jun 2012, 20:39
Hi all - need to tap into your knowledge!! Going to NY Saturday - some advice on the climate - is a NY 25 degrees like a uk 25 or is it more humid?? Really unsure what to pack!! Have noted quite a bit of rain :(
Thanks in advance!
Sx
#812775 by at240
04 Jun 2012, 20:45
Generally speaking, it will feel hotter (in my experience). This is partly humidity, partly air quality, and partly just the oppressive and cramped urban environment on Manhattan.
#812776 by tontybear
04 Jun 2012, 20:46
It will be humid. very.
Sounds strange but take a cardigan/light top because once in an airconditioned building / museum you will likely start to feel cold.
#812780 by honey lamb
04 Jun 2012, 21:04
A lot of it will be reflected heat from the buildings
#812823 by joeyc
05 Jun 2012, 15:48
Just got back from NYC and it was very humid.
Shorts are a must if you are planning on walking around a lot. When exploring the shopping malls, museums and the like I would suggest trousers and a top - the a/c can be pretty chilly.
As I was leaving it was raining and overcast but warm none the less.
Hope you have a good trip. y)
#813054 by roadrunner
08 Jun 2012, 01:52
NYC is likely to be warm although recently weather has been quite cool—but recommend bringing light clothing and a warmer coverup—and shopping if wrong!
#813119 by scally
08 Jun 2012, 19:24
I'm in NY right now, although am sadly heading back to the UK weather tonight.
The temperature here is great - mid to upper 20s at the moment, and not too humid. If you're walking around a lot you'll definitely begin to feel it.
It's been a bit rainy over the past week, on and off, but it doesn't seem to linger around. It's definitely not as hot as it will be in a month or two, when the temperature and humidity really bump up a notch.
Users browsing this forum: Google [Bot] and 166 guests
