#815482 by bonoz
01 Jul 2012, 11:43
Hi guys,
I was hoping to carry my electric guitar (soft-case) as a carry-on in addition to a personal item. I'm hoping I can get it on without problems and store in the cupboards or overhead compartment?
Any advice?
#815492 by preiffer
01 Jul 2012, 13:26
If in Economy, no. As Darren said above (and check the link he posted).
A guitar won't fit in the hand baggage restrictions, and takes up too much of the overhead space in the economy cabin - so it'll either need to be checked into the hold or have its own seat purchased (?!)
You MAY get lucky at the airport and they MIGHT allow it onboard - but I'd go with 10:1 that won't happen, so don't plan on it.
#815499 by preiffer
01 Jul 2012, 13:55
If you're in Upper Class, I've seen them stored in the closets. But then Upper also has a larger cabin baggage allowance too - hence I said "unless you're in Upper".
As you're in Economy, I'm afraid the economy rules apply to you as well as everyone else. (Imagine a plane cabin where 300 people brought a guitar onboard ;) )
#815502 by Spill
01 Jul 2012, 14:42
If you are forced to put the guitar in the hold, you will absolutely need a hard case. Otherwise ir will almost certainly be destroyed. Guitars have sensitive engineering and even a bad knock can ruin then if not properly packeged and looked after. And a "fragile" sticker make no difference what so ever.
The expense of a good quality hard case will be well worth the investment for this.
#815513 by slinky09
01 Jul 2012, 17:15
I've seen passengers in Y take on a guitar and the crew have stowed it in a UC closet, so it can be done. The thing is there is no guarantee, so unless you want to risk it, I'd do as suggested and put it in a hardcase for hold stowage.
#815515 by pjh
01 Jul 2012, 17:25
bonoz wrote:I'm in economy.
So I should be okay carrying as a carry on then? :)
Even if you could, would you want to risk your guitar in an overhead crammed with unyielding cases?
#815768 by Converse120
04 Jul 2012, 12:26
I've twice (2008, 2009) carried-on a guitar in a hard case when travelling in PE from LAS - LGW. Just told the check-in agent I was carrying it on. They were fine and I wasn't challenged about it at any point. Asked for it to be stored in the cupboard. No problems. But of course my experience is no guarantee for you.
Users browsing this forum: Google [Bot] and 157 guests
