Hi all,can anyone tell me if there is an outside smoking facility at the Lhr clubhouse?
Blacky
Blacky
getinjonathan wrote:It is no longer possible to leave for a smoke, or not under normal circumstances anyway. Same applies at Gatwick.
Nottingham Nick wrote:It is airside and right over the airport apron. You can almost chew the fuel vapour - it is quite overpowering. I would therefore assume that the fire risk of discarded cigarettes, matches and other flames must be VERY high, so I have always assumed that is why smoking is forbidden up there.
Blacky1 wrote:Makes sense I guess,maybe time to give up
Also I always seem to get a cold when I get off aircraft these days, is the air not filtered as much on board now?
LovingGold wrote:I do wonder how much extra business VS would get if they installed a smoking facility in the CH, say in the very overused(!!) library.
LovingGold wrote:.
Darren Wheeler wrote:LovingGold wrote:.
None because it cannot currently happen as it would be illegal.
Scrooge wrote:Nottingham Nick wrote:It is airside and right over the airport apron. You can almost chew the fuel vapour - it is quite overpowering. I would therefore assume that the fire risk of discarded cigarettes, matches and other flames must be VERY high, so I have always assumed that is why smoking is forbidden up there.
The sad thing is, you could put a lit cigarette on the ground, throw a bucket of av gas at it and the only thing that would happen is the cigarette would go out.
However, better safe than sorry, though I do now have an image of Rodney (Only Fools and Horses for you youngsters, go google it) flicking a smoke of the roof and watching a row of widebodies going up in smoke.
Users browsing this forum: No registered users and 54 guests
