#826558 by LiamDev
10 Oct 2012, 10:19
Hello v-flyers,
I am going to Mumbai in December on the new A330 UCS with the Mrs. (After quite a few trips over the past 12 months & some CC spend, had accumulated enough miles for some Gs...... :D :D )
Any thoughts on best seats for a couple in the new UC cabin?
#826578 by joeyc
10 Oct 2012, 12:13
Preiffer ha ha ha. Nice one
Avoid row 9 on the a330 unless you also wish to share your seat with the bar. The front few rows also get a lot of back and forth with the front galley. I would recommend rows 4 thru 6 either a or k sides ... Avoid the middle block at all costs - unless you have a conical head, in that case middle block are fine....
Enjoy the new aircraft it is not all bad :D
#826579 by preiffer
10 Oct 2012, 12:15
joeyc wrote:Preiffer ha ha ha. Nice one
Love it - the New Upper Class Dream Suite : In Development since 1993!
http://www.imdb.com/title/tt0106598/
#826600 by ratechaser
10 Oct 2012, 14:39
preiffer wrote:As all passengers are pretty much sat on top of each other in the new layout - I'd say any are good for an "intimate setting"...
...with 40 others ;)
(sorry - couldn't resist)
You know, saw the OP's post early this morning and was tempted to reply with pretty much the same thing... but I'm trying to temper my negativity of the new UCS. I may even try it again someday. For that matter, I may not have any choice!
#826614 by clarkeysntfc
10 Oct 2012, 16:20
I believe you've switched to BA. I'd be very interested to hear your experiences of using BA Club since switching?
#826621 by at240
10 Oct 2012, 17:56
LiamDev wrote:Any thoughts on best seats for a couple in the new UC cabin?
It's the same issue as the 346s -- if you are next to someone in the same aisle, the walls of the suite hinder communication. If you are across the aisle in the same row, you are quite a long way away -- although the distance is noticeably less on the 333.
I think the best advice is to be towards the front of the cabin, as joeyc says. As for same aisle vs. same row -- it's up to you.
Users browsing this forum: cooperman, G-VROY, Google [Bot] and 37 guests
