Hi all,can anyone shed any light on what Ruby Tuesday has been up too since Friday,she has done a couple of trips to Las Vegas but as far as I'm aware has not been used on any other routes,it would be a crime to think people were off on their trips on V-TOP while the lovely refurbished Ruby Tuesday was sitting idle v( Any one with any info out there y)
Where are you flying to? To look up how many times that VXLG has operated your flight Go to The toolbox and click on which aircraft, simply select your flight no and your there. I thought VTOP was supposed to be withdrawn when VXLG returns from maintenance but is leaving in January or February. G-VXLG may have had a technical issue at Gatwick or could be under maintenance there
G-VSHY wrote:Where are you flying to? To look up how many times that VXLG has operated your flight Go to The toolbox and click on which aircraft, simply select your flight no and your there. I thought VTOP was supposed to be withdrawn when VXLG returns from maintenance but is leaving in January or February. G-VXLG may have had a technical issue at Gatwick or could be under maintenance there
I'm not flying with Virgin until March 2013,not quite sure you are understanding the question I'm asking G-VSHY ?|
G-VTOP will be withdrawn by then so you will get a refurbished aircraft. I thought you were flying with them recently, Sorry
I understood!
No official word, but its likely it could be undergoing maintenance, have a technical issue or even a simple case of it could have been flying and the database just hasn't updated.
