#837623 by barny69
11 Feb 2013, 14:01
hi all
ive just come of the phone to va
to book my next flight, using miles ?
they have found a problem with my miles and have taken all of them out of my account.100,000 miles
they say that they forgot to do it last time i flew with them!!!.back in july ?
can they do this .???
help!!!!
THANK YOU
#837626 by Neil
11 Feb 2013, 14:12
As Sarastro has said, if you booked a miles flight and they didn't take the miles (it can happen) then surely you must have realised this has happened and then I would imagine they are well within their rights to do so.
If however you think what they are saying is incorrect or you can prove they did take the miles, then you should speak to them.
#837632 by pjh
11 Feb 2013, 14:46
A bit unusual though. Virtually the moment I book a reward flight the miles due appear as a negative entry in my account.
#837633 by LovingGold
11 Feb 2013, 14:58
Hmm,
I have to agree with pjh here.
Every reward flight I have booked they appear almost instantly as a debit in my account.
I can just echo what others have said. If you did take a flight and a mistake was made you must have known VS may find out.
Trying to understand from your post if you think there has been a mistake and VS are trying to "double dip" from your account or because VS forgot to take then you should be able to take another flight for free as such.
Good luck with that last one. They only have to pull up the transaction history to double check.
#837636 by Neil
11 Feb 2013, 15:05
I know of situations when miles haven't been deducted from an account, and it has never been picked up on.
It is a bit like a situation I have just had. Booked an L fare back in October, eventually upgraded the outbound to PE on 24th December, miles deducted from my FC account, MMB shows as PE but the extra taxes I had to pay hadn't been charged to my card. Knowing that it is an error, when speaking to VS last week to book some more flights I mentioned it and they had forgotten to pass it over to ticketing to charge and reissue the eticket. I know from previous experience that it would have caused a problem on the day and wouldn't have allowed my to do OLCI, so best to 'own up' to the error rather than hope they forget about it.
#837647 by barny69
11 Feb 2013, 16:37
Thanks ,problem seems to have been resolved, 50,000 less miles in account now
Half my mistake half va ?.
Looks like I will be flying Upper only one way now , boo !!
Thanks again
#837648 by Neil
11 Feb 2013, 16:44
barny69 wrote:Thanks ,problem seems to have been resolved, 50,000 less miles in account now
Thanks again
Why not look at buying an upgradable M fare and upgrading both legs with miles to UC?
Good chance it will work out similar cost to a one way full miles fare and a one way standard Y or PE ticket using the combo fares.
#837652 by pjh
11 Feb 2013, 17:03
Neil wrote:Why not look at buying an upgradable M fare and upgrading both legs with miles to UC?
And you get the miles for the M...
#837663 by tontybear
11 Feb 2013, 18:38
I was going to suggest using the fix to display more of your FC Trasanction history do you could check your record yourself ( if someone can find the 'how to' instructions) but it looks like you've resolved your issue with VS.
#837665 by Slipperman
11 Feb 2013, 19:16
tontybear wrote:I was going to suggest using the fix to display more of your FC Trasanction history do you could check your record yourself ( if someone can find the 'how to' instructions) but it looks like you've resolved your issue with VS.
On the 'your account summary' page ... Click 'update', the URL will change, and then in the URL, change the statementselection= bit to 'statementSelection=5'
Users browsing this forum: DoomWolf, Google [Bot] and 8 guests
