#838182 by Davidos
17 Feb 2013, 17:53
I'll be on the new MAN - LHR route in April (VS3046), connecting for a flight to LAX (VS007). My question may seem silly but was wondering if I need to check in at Heathrow for the second leg? Just not sure as the MAN-LHR leg is operated by Aer Lingus in behalf of Virgin.
#838185 by wwings
17 Feb 2013, 18:10
I think you should be able to check yourself all the way through.
I saw on another thread that there would be buses to take connecting pax from T1-T3 and bypassing security (as have already been pre checked by UK border control at MAN).
#838188 by Hamster
17 Feb 2013, 18:19
UKBA have nothing to do with security. Its the airport operator.
I'd expect VS to let you check in all the way through
#838189 by slinky09
17 Feb 2013, 18:23
Yes if you are on a single booking for both legs of the journey VS should check you in in MAN. You may be able to get an airside bus on landing at T1 but you'll still need to clear transit security at T3.
#838191 by Gpik
17 Feb 2013, 18:53
I'm sure on the Virgin website it also states if you have booked the MAN-LHR and LHR-LAX sectors on separate tickets then you just need to advise the check in agent and they will check your bags all the way to final destination for you.
G
#838192 by Hamster
17 Feb 2013, 19:03
Gpik wrote:I'm sure on the Virgin website it also states if you have booked the MAN-LHR and LHR-LAX sectors on separate tickets then you just need to advise the check in agent and they will check your bags all the way to final destination for you.
G
I would hope so as both flights are with "virgin".
#838193 by Davidos
17 Feb 2013, 19:11
Thanks for the responses, I was just a little unsure as it was operated on behalf of Virgin by Aer Lingus. Its just not clear on the booking. It also states it arrives to LHR at terminal 3...is that right?
Outward
Check In: MANCHESTER, MANCHESTER, Terminal 3
Arrive: LONDON, LONDON HEATHROW, Zone A, Terminal 3
#838196 by Gpik
17 Feb 2013, 19:18
[/quote]
I would hope so as both flights are with "virgin".[/quote]
Yeah, I was just advising the OP as they were looking for clarification. ii)
#838197 by clarkeysntfc
17 Feb 2013, 19:46
Davidos wrote:Thanks for the responses, I was just a little unsure as it was operated on behalf of Virgin by Aer Lingus. Its just not clear on the booking. It also states it arrives to LHR at terminal 3...is that right?
Outward
No, the VS short haul flights use T1.
Users browsing this forum: Google [Bot], TomW and 35 guests
