#838944 by David
26 Feb 2013, 08:55
So have booked the first VS departure from EDI down to LHR and the next flight back up again arriving into LHR 8.10 am and departing again 9.05am.
I am assuming I will have boarding passes for both flights at the beginning of flight from EDI so what is the best way to do ?
Do I just arrive and then walk back through security to the same gate ?|
Thanks as always for your wisdom.
#838972 by Hamster
26 Feb 2013, 14:00
No need for security if staying within T1 domestic. You might need to go through flight connections but then back to the gate.
#838991 by DocRo
26 Feb 2013, 20:16
Just hide in the lav :o)
#838996 by mitchja
26 Feb 2013, 20:52
If you have a boarding pass for the return flight, you won't even need to leave the departure gate area.
Just get off the flight, sit down and wait for the return flight to start boarding again. It's probably even the same A/C you arrived on going back to EDI.
#839003 by honey lamb
26 Feb 2013, 21:56
mitchja wrote:If you have a boarding pass for the return flight, you won't even need to leave the departure gate area.
But don't they have those glass walls to separate arriving and departing passengers in T1? They do in the area where the ROI flights go
#839004 by mitchja
26 Feb 2013, 22:05
Not for domestic flights departure lounge area, well they didn't last time I went through T1, which was a year or so ago now.
#839005 by tontybear
26 Feb 2013, 22:19
According to the LHR website you follow the signs to flight connections and simply end up in the departure lounge - no security to go through either.
http://www.heathrowairport.com/heathrow ... 1-domestic
#839012 by DocRo
27 Feb 2013, 00:41
In T1 domestic you exit into the departure area and as Mitchja says you should be able to wait there for the return flight. There is a second ID check coming from the common shopping and restaurant area shared with T1international when there is a biometric type photo comparison with a photo taken before the first security clearance. I'm not sure what the purpose of this is but I don't think it is necessary to validate boarding. As always, I stand to be corrected.
Enjoy your flight
#839015 by Hamster
27 Feb 2013, 03:14
The photo is taken so you dont swap your ticket with an international passenger. A computer uses facial recognition to let you back to domestic in T1 or if in T5, allows you to board your flight.
#839084 by DocRo
27 Feb 2013, 18:48
Hamster wrote:The photo is taken so you dont swap your ticket with an international passenger. A computer uses facial recognition to let you back to domestic in T1 or if in T5, allows you to board your flight.
Ah - I understand. Its to stop a third party avoid immigration. Quite a good system actually. Pity about the occasional very long queues for evening flights.
#839085 by at240
27 Feb 2013, 18:51
DocRo wrote:In T1 domestic you exit into the departure area and as Mitchja says you should be able to wait there for the return flight.
Is there conformance at T1? I don't think there is, but it would trip you up if it did happen.
#839100 by Hamster
27 Feb 2013, 21:44
at240 wrote:Is there conformance at T1? I don't think there is, but it would trip you up if it did happen.
Nope, just T5 at Heathrow. Due to its size/satelights.
Users browsing this forum: TomW and 128 guests
