#840377 by jcc001
13 Mar 2013, 09:37
Hi
I need seat advice ASAP. I am on the VS15 tomorrow in PE with my wife and 2 year old. When I booked the flights the only seats I could get were 19F&G for myself and jnr and 16K for my wife.
I have just checked this morning and upstairs is wide open.
Q. Should I stick to the original seats or should I go upstairs?
Ideally, we would like all 3 in the centre row downstairs.
I am thinking mainly of arriving in Orlando. Am I right in thinking that downstairs PE is allowed to exit the plane before upstairs?
Thanks in advance.
#840378 by CHill710
13 Mar 2013, 09:41
From what others have said downstairs will exit the aircraft first so I would go for a row of 3 downstairs
#840379 by Neil
13 Mar 2013, 09:42
Personally I would stick with what you have got, you are gaining anything by moving upstairs as you still have an aisle between your party.
Regarding disembarking, the upstairs is generally let off at the same time, but obviously with the flow of people, it takes a bit longer as the people on the stairs are having to wait for a gap and filter in, plus you have the 30 odd economy passengers in front of you, rather than just a couple of rows on PE pax behind you.
#840380 by Neil
13 Mar 2013, 09:43
CHill710 wrote:From what others have said downstairs will exit the aircraft first so I would go for a row of 3 downstairs
The OP can't get a row of 3 downstairs, just a 2 and 1.
#840383 by ratechaser
13 Mar 2013, 12:08
Bear in mind though that 19FG are directly opposite the WC, which doesn't sound like a great place to be... on that basis alone I'd probably try and move, even if it didn't resolve the issue of getting 3 seats together...
#840395 by CHill710
13 Mar 2013, 13:13
Oops mis read that bit.
#840417 by Miss G
13 Mar 2013, 19:12
ratechaser wrote:Bear in mind though that 19FG are directly opposite the WC, which doesn't sound like a great place to be... on that basis alone I'd probably try and move, even if it didn't resolve the issue of getting 3 seats together...
It's not, avoid avoid avoid!
Users browsing this forum: TomW and 16 guests
