#2815 by bluefish
05 Oct 2004, 13:43
Hi All
Has anyone booked or flown a K class fare recenlty, I know they are 42day advance purchace, but I can't ever seem to find one, always S
Have they gone, or is it just I can't find them.
Bluefish
#42626 by sahajesh
05 Oct 2004, 19:49
I just bought a return in K on LHR-HKG-LHR for outbound 9/1, inbound 23/1. No issue with this - I checked on the bucket class availability before booking and it showed K1 on the outbound.
It changed to K0 after booking for a few days and is now back to K1 - weird!
Best bet would be to use the availability tool (or I can check for you if let me have the flight details).
Perhaps the route you're looking for is always busy ie SFO is a popular destination so limited availability of K?
Sahajesh.
#42630 by bluefish
05 Oct 2004, 20:06
SFO or Lax, SFO is home two weeks per month.
Will keep surfing away.
Bluefish
#42645 by RichardMannion
05 Oct 2004, 21:50
Yeah they are still around, helps to book far in advance. I prefer the S Class fares though as I can use it with a companion reward or to an upgrade and they are not usually too much more!
Richard
P.S - The band was K-Klass :)
#42730 by colbornjames
06 Oct 2004, 19:30
I can be a bit thick BUT... When you book PE on the website you can get (lowest) or (flexible), however, there are 3 or more PE classes (K,S and W). How do you book an S (of which I'm most interested in as I'd like to use my miles to upgrade in the future)... Everytime I've booked PE I've got K Klass (;))
James
#42733 by RichardMannion
06 Oct 2004, 20:00
James
Flexible will be full W fare, lowest will be K if its available otherwise its a S.
Best way is to phone and check if you need a particular fare.
Richard
#42745 by BlackCat
06 Oct 2004, 21:14
Or if you buy on Expedia or Travelocity (and other online agents) then you can find out the class code (and an explanation of any conditions) from the fare quote page.
BC
#42753 by RichardMannion
06 Oct 2004, 22:18
BC
This won't work on Expedia if its one of their special/consolidated fares :(
If you click on links on the top bar of V-Flyer, and choose Online Booking and Travelocity Code Module - you may find this quite useful as its shows each of the fares, the costs and rules.
Richard
#42779 by BlackCat
07 Oct 2004, 08:51
Yep, but do consolidated fares have the same sort of fare codes anyway?
Unfortunately this doesn't show all the fare codes: I think it has a maximum of 30. I've just checked and it shows down as far as K but not S, W, Z, D or J.
BC
#42782 by FamilyMan
07 Oct 2004, 09:52
Correct me if I'm wrong but neither expedia or travelocity have a premium economy option when searching for flights. I always use OTC http://www.onlinetravel.com as this does. It also has the fare rules at booking stage.
By the way Bluefish - K class is 21 day advance purchase not 42.
Phil (Buffy)
#42784 by mikesmith
07 Oct 2004, 10:50
quote:By the way Bluefish - K class is 21 day advance purchase not 42.
Maybe 21 in principal but at least 42 in practice - they are snapped up very quickly these days. In fact I think K used to be a bit a secret that suddenly got found out - I haven't managed to bag a "K" to LAX in over a year.
#42786 by bluefish
07 Oct 2004, 11:13
know where you are comming form, do west cost twice a months and I the last K i could get was for september last year just before S was introduced IIRC.
#42787 by FamilyMan
07 Oct 2004, 11:15
quote:Originally posted by mikesmithMaybe 21 in principal but at least 42 in practice - they are snapped up very quickly these days. In fact I think K used to be a bit a secret that suddenly got found out - I haven't managed to bag a "K" to LAX in over a year.
I disagree. Try the link provided above - I am finding loads of availability for LHR-LAX in K well inside 42 days (e.g. out 28/10 back 8/11 for £962). Tip. Use the availabiity tool first to find K class availability then search for fares.
Bluefish - you're a SFO man aren't you - out 28/10 back 7/11 - K Class £979.30.
I know the dates might not suit but the fares are there and well inside 42 days. I grant you weekends are tighter.
Maybe someone can shed some light on why availability for K still shows up on flights less then 21 days out - does this just get bundled into S class?
Phil (Buffy)
#42797 by bluefish
07 Oct 2004, 11:55
Thanks Buffy
Yep SFO, and usually on a Sat to Sat hence the problem for me, but I had not seen mid weeks for a while, hold on credit card, here I come.
In answer to you question, I was once told by Flying club that you can still by a K class ticket the day before, but it will full fare, but bot flexible IIRC.
Thanks for your help
Bluefish
#42813 by mikesmith
07 Oct 2004, 14:45
quote:september last year just before S was introduced
I hadn't realised that S-class was introduced only a year ago. That explains a lot.
Buffy, I agree that it is still quite easy to get a K fare for mid-week flights but before last September (2003) it was just as easy to get them on the Sunday departures aswell.
I suppose I need to try and arrange trips more in advance to get the Ks but that would mean that there is a higher risk of needing to make changes which would mean I would better off with S-class anyway.
#42815 by bluefish
07 Oct 2004, 14:52
The reason I think we don't seem to see as many K is also not that they do not exist but that they don't hang about as long. But also sales fares have not been offered in PE as much this year.
I purchased 3 K's in July last year for travel on October and November, for the seats to then be put in the sale, this meant I was about £1k out of pocket but it did proably make it feel as if more seats were available?
Just a thought, does anyone know it it is a fixed amount of K's per flight
#42851 by colbornjames
07 Oct 2004, 19:24
I don't think they are fixed... I watch fares for a few weeks before I buy and the prices fluctuate. I've only flown twice on Virgin, both PE and they've both been K fares.
Maybe it is availability per route, however, I fly BOS - LHR which is always overbooked.
FYI - If you use Expedia Corporate travel they tell you the class of flight but Expedia for personal doesn't list them.
J.
