#853626 by hat
05 Aug 2013, 13:42
A work colleague & I will be flying out of LHR on Sunday 18 August in UC. If anyone can make use of our guest Clubhouse access just let me know. We'll be transiting on LR from MAN should be in the CH by 12:30-1:00pm.
#853629 by lovetoholiday
05 Aug 2013, 13:45
Don't forget under the new rules they need to be on the same flight as you.
Hope that helps
L2H
#853633 by lovetoholiday
05 Aug 2013, 13:46
Wow, 3 replies at the same time, aren't we a helpful responsive bunch :-D
#853638 by hat
05 Aug 2013, 14:11
I missed that update. That's a bit tight, narrows down the chances to almost zero - what are the chances of someone you know travelling on the same flight but in a lower class or not at Au status?
We're on the Boston flight if it's still of any use to anyone?
#853672 by honey lamb
05 Aug 2013, 19:36
gumshoe wrote:A kind offer - you'll need to tell us what flight you're on though,
He didn't, because if you had hovered your mouse over the little plane beneath his username you would have seen he was going to Boston. |:) |:)
#853676 by gumshoe
05 Aug 2013, 19:49
honey lamb wrote:He didn't, because if you had hovered your mouse over the little plane beneath his username you would have seen he was going to Boston. |:) |:)
Ah ok - alas that function isn't available on the mobile version of V-Flyer for the mouseless!
#853679 by tontybear
05 Aug 2013, 19:55
hat wrote:I missed that update. That's a bit tight, narrows down the chances to almost zero - what are the chances of someone you know travelling on the same flight but in a lower class or not at Au status?
It's only recently come into force - with very little formal publicity.
The policy was probably initially designed to allow family members, friends or work colleagues i.e. people you would actually know and talk about your trips with into the CH rather than to invite random strangers off the interwebs.
Mind the new policy still doesn't stop the latter but restricts the numbers down a little.
#853685 by honey lamb
05 Aug 2013, 20:47
Ah, I never thought of that. Sorry.
