#857909 by poggsuk
20 Sep 2013, 19:29
I am about to book our annual trip to Florida and was thinking about using virgin little red for the first time rather than BA for the Edinburgh to London segments. Do virgin provide any assistance for the heathrow to Gatwick transfer or am I on my own? If on my own what is the conformance time? Should I get stuck in traffic, will Virgin protect me onto the next flight? thanks
#857923 by gumshoe
20 Sep 2013, 21:01
I don't know for sure but I suspect you're on your own. You're certainly expected to make your own way from LHR to LGW, with your luggage, at your expense. The fact none of the LGW routes are available as options if you select EDI as your start point suggests they're not considered connections which would be honoured in the event of problems.
But you never know - that might not be the case: try calling them. Even if they're not legally obliged to rebook you on to a later flight in the event of a delay VS will normally do what they can to help if things go wrong. Failing that, would your travel insurance cover you?
I'd allow 4 hours between your LHR arrival and LGW departure to be safe - bag drop at LGW will close an hour prior to departure and VS recommend you're there 2 hours prior.
As an alternative have you considered the VS flights to Orlando from Manchester? There's a direct train from Edinburgh to Manchester Airport at about 7.45am which connects with the VS73. It takes about 3.5 hours but by the time you've schlepped round the M25 from LHR to LGW you'll save time, not to mention hassle.
#857939 by CHill710
21 Sep 2013, 06:39
If you can I would be tempted to fly down on LR the day before and stay somewhere around LGW for the night. At least then you shouldn't have to worry about connections.
National express run frequent coaches between the 2 airports.
The Travelodge at gatwick (Central) is usually quite reasonable and has a local bus stop serving LGW just outside as well as the airport shuttle.
#857940 by poggsuk
21 Sep 2013, 06:57
thanks for the replies. I think I'll just stick to the Ba flight to gatwick then, booking with expedia or the like to get it all on one pnr. Just wanted to keep all my business with virgin if I could. Don't 'do' Manchester any more. Cant stand that airport. It always seems such a shambles.
Users browsing this forum: Google [Bot] and 49 guests
