#859449 by at240
14 Oct 2013, 10:27
Good morning --
I remember there's a quick lane at T4 for those with connections. Is this open to you if you have booked a separate ongoing flight -- or does the whole itinerary need to be on one PNR?
Thinking about risking the VS45 again, you see...
Thanks!
#859459 by Blacky1
14 Oct 2013, 11:50
Not sure about the answer at240 but the mention of the 45 just sent a shiver down my spine !
#859473 by at240
14 Oct 2013, 14:48
Immigration queues can be bad -- I've been lucky in the past but this time may have a connection.
#859479 by declansmith
14 Oct 2013, 16:22
Quick connect..
Flight needs to be departing within three hours and you just need to show onward boarding card or itinerary :-) contact ground staff when you step off the aircraft.
#859485 by Kraken
14 Oct 2013, 18:30
I've done the VS45 twice and have been very lucky - through immigration in under 10mins on both occasions. The queue for a taxi at the front of the terminal took longer.
I do know from reading trip reports on here, waits of up to 2hrs for immigration when arriving on the VS45 are not unheard of. Ouch.
#859486 by Blacky1
14 Oct 2013, 19:05
Kraken wrote:I've done the VS45 twice and have been very lucky - through immigration in under 10mins on both
Nearly 3 on my first visit
#859487 by Turquoise
14 Oct 2013, 19:23
I have had a lengthy wait too on all 3 occasions I have been to NY. If I go again, and I do so want to (!), will definitely avoid the 45! Last time, we waited nearly 3 hours to get through.
#859491 by at240
14 Oct 2013, 20:04
declansmith wrote:Quick connect..
Thank you Declan -- the name had escaped me. Much appreciated. y)
#859499 by bebop
14 Oct 2013, 20:48
Crumbs. I booked tickets on the 45 for travel next year only the other day. Didn't even cross my mind immigration queues could be that long. Yikes.
#859517 by duggy83
15 Oct 2013, 13:11
Daniel Armstrong wrote:Went last time on 45 - it was 3 hours...
This time I am on VS3, I have been told this is a much better time and you wizz through... Anyone know if this is right..?
Was literally an empty hall when I last took the VS3 - was outside and in a cab (with luggage) 20 mins after getting off the plane!
#859518 by Gonzo
15 Oct 2013, 13:27
Oh the 45... I have used this many many times and the immigration line can vary wildly. I think that there are a lot of European flights that arrive at roughly the same time as the 45 hence the long lines.
If at all possible I go for the early flight across which in my experience has less line trouble at immigration though this does mean i have to organise my travel arrangements differently. Thankfully I don't have to use the Taxi rank (Looking at the line for that on the 18th of sept made me wince !) and that was a lunchtime landing too.
I have on occassion used the train link to Jamaica station which is fine, however, if using this please note that it will cost you $5 to pass through the barrier. There are plenty of trains to take you in either direction and platform information is fairly good.
The other issue with T4 is the security at departures, oh how I used to love it when you could check in then proceed down to duty free, grab a coffee and nip back outside to join all the other unfortunates like myself in smokers corner(s).
Having watched as they built the new security channels over this last year I was hoping that at least the lines would be shorter getting through... but oh no... I couldn't believe how long it was !!.. fortunately I had cunningly upgraded and could use the sneaky UC/Buss class line... phew... only 3 in front ! ):
Users browsing this forum: No registered users and 39 guests
