#864233 by Neil
11 Jan 2014, 20:49
It depends on when your flight is and where you are flying to. Virgin are introducing a new paid for seat reservation system but it is being introduced in stages and this has meant that they have temporarily adjusted when you can reserve seats depending on when your flight is.
All the info can be found on the VS website, this page is a good place to start.
#864235 by gumshoe
11 Jan 2014, 21:13
As Neil says it's very complicated at the moment. When and where are you flying?
#864363 by rjhsteel2001
13 Jan 2014, 15:48
From online help:
Adam : There will only be a certain percentage of seats released for passengers to pay to pre-assign prior to online check-in, this may be a mixture of seats on the lower an upper deck.
Adam : We are unable to know if the upper deck seats will be available to pre-assign with the extra charge, or if they will be kept to assign at the time of check-in.
#864364 by gumshoe
13 Jan 2014, 16:01
robinsonad86 wrote:Hi Im interested in this question to Im flying LHR-JFK on August 29th
Welcome.
You should be able to select your seat on June 1st. If you're flying economy it'll cost £25 unless you're a Flying Club Gold member or you have a ticket in the most expensive, fully flexible economy bucket (Y) in which case it will be free.
#864421 by robinsonad86
14 Jan 2014, 00:39
Thanks both have booked through Virgin Holidays and paying instalments. I think its paid off by this date but if it isn't would I still be able to pre-select seating?
Interesting about upper deck as I think they would be preferred seats as girlfriend terrified of flying think quieter cabin would help her
#864424 by gumshoe
14 Jan 2014, 05:36
You'll only be able to select seats with the airline booking reference (6 letters and numbers) which Virgin Holidays should give you in your documentation.
Whether they'll give you that until it's fully paid up I don't know I'm afraid.
#864425 by mitchja
14 Jan 2014, 06:33
With all VH bookings, VS have a work-around in place allowing seat selection as soon as the flight bit is booked with VS, so can be upto 11months before you travel and before you have paid your final balance and been ticketed.
All other T/A bookings can only select seats once VS has ticketed the flight, which is generally around 2 weeks before departure.
#864754 by interlog
17 Jan 2014, 22:50
rjhsteel2001 wrote:From online help: Adam : There will only be a certain percentage of seats released for passengers to pay to pre-assign prior to online check-in, this may be a mixture of seats on the lower an upper deck.
I think that this is just wrong. When you're paying to select a seat then surely you should have the pick of all of the seats on the plane (except extra leg room / emergency exit / bulkhead) seats rather than a limited selection?
#864773 by hunterdwmgzt
18 Jan 2014, 09:59
mitchja wrote:With all VH bookings, VS have a work-around in place allowing seat selection as soon as the flight bit is booked with VS, so can be upto 11months before you travel and before you have paid your final balance and been ticketed..
Hi James,
Are you sure about this?, as we have just booked with VH to go to Barbados in August and I'm told we can't select seats till 1st May?
