#868261 by david22294
12 Mar 2014, 00:06
I was having a look online and came across this article. I cant say i am over the moon that virgin are sticking with the dream suite and it sounds like it will be as cramped as ever. I hope the website is wrong and that virgin will rethink the suite.
What will you find inside the Virgin Dreamliner? The 787-9 will have three cabin classes with a total of 250 to 290 seats, depending on the configuration. Up front, there’s Virgin’s Upper Class business product (above), with the latest herringbone seating just re-introduced on the Airbus A330-300, with presumably the famous in-flight bar. Seating is now 1-2-1 across on the A330, which is denser than 1-1-1 previously on the A340, so we’re curious to see whether the narrower body of the 787 will get 1-2-1 as well
What do you all think? Here is the Link http://www.jaunted.com/story/2014/2/19/ ... t's+Inside
#868263 by joeyc
12 Mar 2014, 00:34
Agreed with David, that article is pure speculation with no real fact or source material cited. Clearly a slow news day over on jaunted :P
#868271 by slinky09
12 Mar 2014, 08:01
Seating was reported to be 1-2-1 BUT the B787 is wider than an A330 (one of many factual inaccuracies in the article) so I'm hoping for something better than the disastrous UCDS. If rumours are to be believed, it will be a new seat in any case.
#868274 by jfenney
12 Mar 2014, 09:08
virginboy747 wrote:It will not be the dream suite but an enhanced version of the original suite
Wasn't the dream suite an enhanced version also? Well experiencing this for the first time in 8 days so will let you know my thoughts y)
#868275 by enjoyingit
12 Mar 2014, 09:21
slinky09 wrote:Seating was reported to be 1-2-1 BUT the B787 is wider than an A330 (one of many factual inaccuracies in the article) so I'm hoping for something better than the disastrous UCDS. If rumours are to be believed, it will be a new seat in any case.
Fingers crossed
#868279 by Fuzzy14
12 Mar 2014, 11:25
Interior widths
A330 5.28m (17ft 4")
B787 5.77m (18ft 11") (ellipse)
B777 5.87m (19ft 3")
B747 6.10m (20ft) (oval)
If 1-2-1 fits in an A330 then don't see any reason why it wouldn't fit in a 787.
Back in economy on the A330 other operators use a 3-3-3 configuration which is a bit of a squeeze, Virgin are 2-4-2. However with the extra 490mm to play with I'd expect Virgin to have 3-3-3 config on their 787s (opinion).
#868284 by Smid
12 Mar 2014, 12:13
No.
Dream Suite is like taking the previous configuration and squishing it right up, then crowbarring a bar at a funny angle at the end.
It's bearable, but not in any way an improvement.
I suspect the idea that it is, is perpetuated by the likes of tripadvisor, and talking of which, we're due someone turning up asking if a 747 is likely to have been refurbished, and to specifically use the term 'tired'.
#868298 by slinky09
12 Mar 2014, 15:07
Smid wrote:No.
Isn't that how a bean counter would describe 'enhance'?
#868328 by ultreen1
12 Mar 2014, 23:14
I'm looking forward to the enhancement!
#868329 by Stevieboy
12 Mar 2014, 23:28
I was speaking to the FSM's on my recent flights to and from DXB and they both confirmed this. One went as far as telling me that the seat had to be redesigned after very negative feed back from passengers.
Also said that the last she had heard was the first one should be delivered in September and was going to BOS.
-Steve
#868330 by David
12 Mar 2014, 23:31
Can anyone confirm the A330's are staying after all the 787's are delivered. ?
Seem to think they were actually a bit of a stop gap because the 787's were so far behind schedule.
#868335 by SRH
13 Mar 2014, 00:18
David wrote:Can anyone confirm the A330's are staying after all the 787's are delivered. ?
They were a stop-gap due to 787 delays but as far as I'm aware they're all staying. It's the A340's that will be going.. Then at some point I imagine the 747's will be going too.
#868350 by at240
13 Mar 2014, 09:06
flyingfox wrote:And here's hoping they retrofit the "enhanced" UCS in 111 config on the A330.
Rather than going to the expense of that, they could refit the dream suite 111 and perhaps remove a row or two to space them out more. That would improve the 333s immeasurably.
#868357 by RyanJW
13 Mar 2014, 09:50
at240 wrote:Rather than going to the expense of that, they could refit the dream suite 111 and perhaps remove a row or two to space them out more. That would improve the 333s immeasurably.
With options for another 8 dream liners there is a distinct possibility to switch out the a333's with the 789's with a policy of just fleet renewal and not expanding.
#868358 by at240
13 Mar 2014, 09:58
But that would surely incur needless extra costs which I can't believe VS would be keen to run up at the moment. I really can't see them mothballing the 333s so quickly. They are far from disastrous -- aside from the UC seating density, they are a fantastic plane.
#868361 by flyingfox
13 Mar 2014, 10:07
I think it would be rather hard to remove any seats in the middle row as they are interlinked and don't look like they are separate modules.
VS will keep the A330, it's an economical aircraft and is embedded now, unless DL take them on there here to stay.
#868363 by wwings
13 Mar 2014, 10:17
RyanJW wrote:
They only have options for 5 more 787's. Also don't forget the A330's are on 10 year leases like the 340-600's were - so will be around for at least another 8-9 years.
#868369 by RyanJW
13 Mar 2014, 11:33
flyingfox wrote:VS will keep the A330, it's an economical aircraft and is embedded now, unless DL take them on there here to stay.
DL definitely like the A330 with over 30 in their fleet. I'm not saying they will be getting rid of them as soon as the 789's arrive, I do think there is a possibility that the A330's might eventually be replaced or shifted over to DL to replace some of their older, as let's not forget they are not going to get 16x 789's all within a single year but spread over multiple delivery dates in sync with removing the A340's.
With the first A330 that came online around 2 years ago, if the 10 year lease is accurate, just adding up the timelines would potentially be the time frame that some options of the 789 might be available if they confirm them in the next couple of years.
Wwings - I thought they had options for 8x and all the relevant sources do say 8x unless I missed something somewhere!! :) They also said they have potential purchase rights for 20 more after their options if its a successful aircraft for VS.
Just some thoughts!!
Users browsing this forum: jilly and 30 guests
