#878179 by olisones
16 Jul 2014, 12:03
Hi all,
Looking at the AMS tick to HKG in October and the quickest flight Expedia is giving me is AMS to LGW then out to HKG from LHR. It's only got a 3hr30m layover between the two flights. Has anyone had experience of making this gap? It seems a little tight to me.
Any thoughts?!
O
#878180 by panther34
16 Jul 2014, 12:08
Depending on the costs your willing to pay, you could get the Gatwick Express to Victoria (30 Mins) then catch the Tube from there to Heathrow (55 mins ish). Adding transfer times, baggage reclaim/customs etc you should be ok, unless its exceptionally busy when you get to Gatwick.
#878183 by olisones
16 Jul 2014, 12:13
panther34 wrote:Depending on the costs your willing to pay, you could get the Gatwick Express to Victoria (30 Mins) then catch the Tube from there to Heathrow (55 mins ish). Adding transfer times, baggage reclaim/customs etc you should be ok, unless its exceptionally busy when you get to Gatwick.
I think we would most likely get a taxi from LGW to LHR as we'll have a lot of luggage. I was just concerned about check ins/bag drops closing at LHR.
#878184 by HWVlover
16 Jul 2014, 12:14
National Express reckon a coach journey of just over an hour, for £25.
y)
#878185 by gumshoe
16 Jul 2014, 12:21
olisones wrote:Looking at the AMS tick to HKG in October and the quickest flight Expedia is giving me is AMS to LGW then out to HKG from LHR.
Seriously? There's a 1915 BA flight from AMS to LHR arriving at 1930 which would be perfect for the VS200. There should be no reason to have to go via LGW.
I think Expedia spits out results in order of price so if the LGW option's cheaper it'll offer that first.
#878230 by Sarastro
16 Jul 2014, 17:16
If you must do a LGW-LHR transfer in either direction, don't even think about using the two Expresses with a tube in the middle. It's a ghastly way to do it. I used to work in Gatwick and for Heathrow flights I swear by National Express - door to door, no faffing about, and I found it remarkably punctual. Worst trip I had was 1:25, and the M25 was a complete mare - so much so that the driver took the bus off at the M3 and wound his way up from there...
#878232 by MrDoob
16 Jul 2014, 18:03
Guess you are not doing it in upper or as an FC AU, since 3:30 isn't enough for the jouney and the clubhouse :) Surprised it is that much cheaper in Economy to make it worthwhile.
#878237 by International Hitman
16 Jul 2014, 19:28
MrDoob wrote:Guess you are not doing it in upper or as an FC AU, since 3:30 isn't enough for the jouney and the clubhouse :) Surprised it is that much cheaper in Economy to make it worthwhile.
I've done same trip [AMS-HKG] many times ---- ISTC but Expedia/AMS trick on this route only works UC? :?
Sarastro wrote:If you must do a LGW-LHR transfer in either direction, don't even think about using the two Expresses with a tube in the middle. It's a ghastly way to do it. I used to work in Gatwick and for Heathrow flights I swear by National Express - door to door, no faffing about, and I found it remarkably punctual. Worst trip I had was 1:25, and the M25 was a complete mare - so much so that the driver took the bus off at the M3 and wound his way up from there...
I live equidistant to LHR/LGW [Guildford]so know this section of M25 extremely well -- never did National Express, but makes perfect sense as Sarastro descibes :)
#878305 by olisones
17 Jul 2014, 12:28
Oh yes I'll be doing UC - it's a long trip without it! But yes, this would severely limit our time in the CH, if any at all. Maybe enough time to pop in for a drink but that's about it!
Users browsing this forum: Google [Bot], ScoobySu and 13 guests
