#879792 by philm
08 Aug 2014, 14:23
How can I get a front row seat on Virgin Atlantic Little Red? When I try and reserve it online the row is always blocked out.
Does it help that I am a Flying Club Gold member? It would be good if Gold Card holders could get these seats in advance.
Thanks in advance for any help and advice!
#879795 by gumshoe
08 Aug 2014, 14:38
Hello and welcome.
No, Au members have no priority when it comes to choosing seats.
Row 1 normally becomes available online a few hours before OLCI opens at T-24. It used to be quite easy to get seats if you were "in the know" but as the flights have become fuller and more people have wised up to it, it's now pretty much pot luck.
Mind you the only real advantage of Row 1 is getting off first. Chances are you'll have to go a bit further back to store your hand baggage as there's only a small amount of locker space above Row 1. And while there's extra knee room, you can't stretch your legs because of the bulkhead.
The emergency exit rows 12 & 13 are better space-wise, if you don't mind a wait to disembark. And in my experience they ARE sometimes proactively offered to Au members, if you're early enough at bag drop. They're never reservable online, only at the airport.
#879796 by mitchja
08 Aug 2014, 14:41
Welcome to V-Flyer :)
Yep, I've always found row 1 opens up around the T-28hrs mark. I've been lucky so far and manage to grab row 1 on pretty much all my VLR flights :)
#879802 by LucyLu
08 Aug 2014, 15:22
I got row 1 out and back on my trip to ABZ from LHR recently.
For the outbound trip I selected it a couple of hours before OLCI opened but on the return I only looked for it once OLCI had opened and still got it.
Downside I found was that you have to put all hand luggage in the overheads and there is limited space at the front of the plane due to safety equipment etc.....plus row 1-5 are the last to board, so most of the overhead space has already been bagged. I was lucky as I checked my bag in and only had a handbag, but if I had a trolley case I would have had problems.
#879853 by McCoy
09 Aug 2014, 07:54
2D is my preferred seat.
And my hand luggage is almost always small enough to go under the seat in front, so I tend to board last.
Row 1 isn't the legroom nirvana it sometimes is on other aircraft.
#879916 by honey lamb
09 Aug 2014, 22:18
Row 1 on Aer Lingus is treated as an exit row. Given that LR is operated by EI you may find that that is the same and the overhead space there is usually taken up by the stuff crew need for the safety demo and a few things.
Users browsing this forum: Google [Bot], ScoobySu and 15 guests
