#885506 by saverton
15 Oct 2014, 11:45
I fly LHR - CMH next week on a VS code share. Normally I would have lounge access in T3 due to VS Au status but this flight is a Delta flight from T4 and connect to CMH via ATL. In T4 Delta have a shared "SkyTeam" lounge.
The simple question is, do I have access to the lounge or not? (unfortunately the answer appears to not be that simple) no one seems to be able to answer this for sure...the last advice I was given was "turn up and see if they let you in!"
Any ideas?
#885508 by JCBR
15 Oct 2014, 11:49
I would expect that if it is a VS code share AND you are ticketed on VS then the Au card should get you in.
There are certain credit cards that will also get you in.
#885513 by tontybear
15 Oct 2014, 12:25
If they do let you in then go upstairs. It will be a lot quieter than downstairs but apart from a few minor things the offer is just the same.
I did a TR with some comments in a couple of years ago
DL148
I read today on Head for Points that they accept Priority Pass now
