#886564 by NYLON
29 Oct 2014, 10:42
Flying DL BusinessElite actually qualifies you for both (DL Sky Club and VS Clubhouse) JFK lounges. In fact, I "multi-lounged" on my last DL BE trip...
And - a reminder - you can also use VS Revivals lounge upon arrival, in LHR T3 as it's a DL/VS codeshare flight.
See here: http://v-flyer.com/forum/index.php?f=4& ... =viewtopic
Hope this helps.
NYLON.
#886597 by pjh
29 Oct 2014, 16:31
NYLON wrote:Flying DL BusinessElite actually qualifies you for both (DL Sky Club and VS Clubhouse) JFK lounges. In fact, I "multi-lounged" on my last DL BE trip...
Hope this helps.
NYLON.
Does the fact you are AU make a difference?
#886599 by Syrome
29 Oct 2014, 16:43
Hope this helps.
NYLON.
Nope. All BE passengers are eligible.
http://www.delta.com/content/www/en_US/ ... -faqs.html
#886607 by NYLON
29 Oct 2014, 17:20
joeymello wrote:Good question!
If you're a VS Gold member flying Delta domestic departing from JFK (crediting the flight to VS), would you have access to the JFK Clubhouse at Terminal 4?
Not domestic, alas; you'd need a "same-day nonstop transatlantic flight to the U.K." on a DL/VS codeshare.
#886619 by sf
29 Oct 2014, 19:07
Hope this helps.
NYLON.
Thanks. Missed your original post but that's good to know. Revivals access is definitely a plus y)
#886662 by carolinaRN
30 Oct 2014, 02:40
I am VS gold and fly delta domestic out of terminal 4 all the time. I have never had an issue getting in....as long as you have your gold card you should be good to go.
#886663 by slinky09
30 Oct 2014, 06:20
That's interesting, and not my understanding of the rules too. But good for you, stay hush!
#886674 by NYLON
30 Oct 2014, 11:18
You might have been lucky all these times (and good for you, as Slinky says!). About two weeks ago I was in the JFK CH and saw two DL domestic pax turned away at reception for not having a transatlantic flight to LHR.
#886716 by joeymello
30 Oct 2014, 17:14
Thx! I'm VS Au based in NYC and when flying domestically I'll give this a shot and will make sure to bring my Au card. I have tried to get in the DL SkyClub since it's closer to the DL gates (10 min walk to VS Clubhouse from DL Terminal 4 area).
