#888303 by ScoobySu
18 Nov 2014, 15:00
Hi
Having now booked 10 & 11 A outbound for April hubby has put a spanner in the works ii) .
When we flew on the VS043 to Vegas we got some stunning pictures of the Grand Canyon when we were sitting on the starboard side so he's now asked if we could sit on the same side.
Does anybody know if the VS023 takes a similar route? ?| If so I'll switch to 5 & 6 K.
Many thanks in advance!
ScoobySu
#888305 by jmacconnacher
18 Nov 2014, 15:12
It normally follows a very similar routing although this can very slightly depending on weather conditions.
The last few flights I've taken you do get a view of the Grand Canyon, however you are still at cruising altitude and this point so it doesn't seem quite so spectacular. You can normally see Vegas from the other side which is good.
Descent into LAX does not normally start until well past Las Vegas and over the Mojave so you're free to roam around the cabin and take in the view from both sides.
