#885871 by djack8
19 Oct 2014, 22:14
Was told by a friend today that VS and BA are going to be swapping terminals at LGW to accommodate Easyjet. I have a few questions -
1. Is this true? If so, when?
2. Will it be a direct swap of facilities of VS and BA?
3. Will this be a good move for VS?
Any replies appreciated.
Dan
#885877 by tontybear
19 Oct 2014, 23:32
I imagine that they are doing detailed negotiations over the practicalities over the moves and future operations and the financials - i.e. how much LGW and/or Easyjet are willing to cough up to both VS and BA to construct the replacement lounges etc before any moves take place. Ditto with V-Hols and the V-Room
If IIRC the VS CH was refurbished only a couple of years ago and the v-room is still fairly new too so VS won't be too willing to move without some form of compensation.
#885881 by tontybear
20 Oct 2014, 00:01
seany wrote:Is the idea that EZY will move all flights to the north terminal?
Yes.
#885882 by djack8
20 Oct 2014, 00:41
Is the BA facilities (lounges etc) a good but larger than VS's in the south terminal? If/when this goes ahead, do we know if VS will be using the new BA check in area, or will that be Easyjet?
Dan
#885927 by WazneB
20 Oct 2014, 16:06
Didn't Gatwick put a massive new expansion at North just for BA to move into in 2012 ? I wouldn't have thought BA would want to move from their sparkly new high tech home (I remember watching that on the Inside Gatwick program Sky had on a while ago)
#885930 by gumshoe
20 Oct 2014, 16:44
WazneB wrote:Didn't Gatwick put a massive new expansion at North just for BA to move into in 2012 ? I wouldn't have thought BA would want to move from their sparkly new high tech home (I remember watching that on the Inside Gatwick program Sky had on a while ago)
Yes they did, and IIRC BA had substantial input over the design & facilities.
One can only assume Gatwick's owners will make it worth BA's while to move.
As LGW's biggest airline you can understand EZY wanting to consolidate - but I wonder how they approached LGW: "we'll pay you lots of money if you let us" or "we'll pull out if you don't".
#885935 by WazneB
20 Oct 2014, 17:51
But would EZY move in to that or would VS, I can't really see BA wanting either of them moving into something they helped design, and would it be then that BA has the majority of the South Terminal to itself ? Also would Gatwick have the sort of money to revamp the south to accommodate BA after seeing what they did for them in the North Terminal. Someone will need to splash some serious cash about if the swap is to be a done deal.
#885939 by PaulS
20 Oct 2014, 19:05
I had a conversation with some BA people in he F lounge and the move is openly being discussed. They also intimated that BA had big expansion plans should the second runway be built, so it could be that they plan to redevelop the south terminal should this happen
#892876 by slinky09
19 Jan 2015, 15:08
Over on FT there's a discussion about BA moving to Gatwick South Terminal in November this year (new check in area and new lounges being built).
It also says that VS is moving to the North terminal ...
Apparently this is all because EasyJet, which is easily the biggest carrier at LGW, wants to consolidate its operations in the North Terminal.
#892886 by David
19 Jan 2015, 15:41
slinky09 wrote:Over on FT there's a discussion about BA moving to Gatwick South Terminal in November this year (new check in area and new lounges being built).
Think its Nov 2016 - this was reported a few months ago as a rumour but not confirmed.
I quite like the South Terminal now all the works been down but a move makes the Clubhouse an interesting issue.
I thought BA's check-in area had all been redone recently in T1 but I suppose EasyJet would grab that.
#892891 by slinky09
19 Jan 2015, 16:25
David wrote:I quite like the South Terminal now all the works been down but a move makes the Clubhouse an interesting issue.
There will have to be a new one ... that'll be fun!
#892893 by oldboy
19 Jan 2015, 16:55
Only terminal I have used at Gatwick in recent years is the South for holiday flights with VS, years ago I used to use North terminal when flying BA to Caribbean & used to prefer that terminal, must be 15 or so years ago though so no idea what it is like now, as long as there is a Club House I will be happy.
oldboy
#892894 by tontybear
19 Jan 2015, 16:56
Yes it was mentioned last year and more than in just general 'it might happen' or 'it would be good if ... ' terms but in 'yes this is going to happen and all we have to do is cross the t's ...'
Both Easyjet and BA will be able to consolidate their operations into one terminal (currently both split) which will help reduce delays.
VS have probably got a good deal out of LGW to pay for a new CH and VH for the V-room.
It's interesting that BA have to take second fiddle at LGW to Easyjet unlike their dominance at LHR
#892913 by slinky09
19 Jan 2015, 18:46
mallin wrote:Hope its not till next year as have just booked our hotel and parking for this OCTOBER. As TCB had an extra 10% bonus on this weekend got over £30 back on cashback. Lin y)
Dates appear to be November, but could easily slip as there's a lot of work to be done.
