#893447 by contractor
24 Jan 2015, 10:01
Hi, does anyone have a link to the old booking page where one could select the booking class? I'm trying to look for S fares.
Thanks.
/C
#893449 by contractor
24 Jan 2015, 10:27
don't worry, found it at
http://www.virgin-atlantic.com/en/gb/fr ... /index.jsp
(select money fares and another input field appears)
#893450 by marshy11
24 Jan 2015, 10:43
Does that still work?
I use the ITS Matrix and input the fare code, for example for m:
VS / f bc=m
#893479 by gumshoe
24 Jan 2015, 14:58
No, that feature still doesn't work.
It LOOKS like it does, as it lets you select your fare code, but try selecting an S and the fare it comes back with is a K.
You'll either have to call FC or, as mentioned previously, use ITA Matrix if you can.
#893506 by property1925
24 Jan 2015, 19:23
I just call FC and ask for an S fare. If the agent is on the ball - they usually are - they will ask you if you want to check for a G upgrade there and then
#893513 by Silver Fox
24 Jan 2015, 20:08
dickydotcom wrote:
marshy11 wrote:Does that still work?
VS / f bc=m
Well, I've just spend an enjoyable hour learning about ITA matrix here.
http://travelcodex.com/2012/01/introduc ... using-ita/
It may seem a bit daunting at first but is reasonable easy to follow.
Dick D
Thanks for that, you reminded me that I need to bookmark it.
#893517 by marshy11
24 Jan 2015, 21:55
Sorry for the ipad typo. ITA, not ITS or even ITV!
#893526 by ultreen1
25 Jan 2015, 00:19
I can't get to grips with the ITV, ITS or ITA matrix ;)...thanks to DD for putting that link up. I'll have a read in the morning after the Chardonnay has worn off!!!
#893543 by marshy11
25 Jan 2015, 09:16
Darren,
I just go to https://matrix.itasoftware.com and put the departure, arrival airports and dates in. Then hit the advanced routing link. Add in the little code I put above (obviously change the m if you want a different bucket) and hey presto.
This comes up:
Hit the 'details' tab on the far right and it gives the full info for the flight.
Sorry if the images aren't too clear but I had to keep reducing them down to fit.
#893575 by contractor
25 Jan 2015, 16:09
gumshoe wrote:No, that feature still doesn't work.
this one works
http://www.virgin-atlantic.com/en/gb/bo ... /index.jsp
make sure you select flexible fares for S
