#897368 by hmvs_dog
02 Mar 2015, 19:24
Evening all,
I'm travelling to SFO in J later on this month and am investigating power options for my late 2014 Macbook Pro 15.
From what I understand, there isn't enough power in the Empower sockets on the aircraft to power the machine (I know it's wouldn't charge, that's against policy anyway), and Apple have discontinued their Empower to Magsafe adapter (not that it would have worked anyway, if the port does not supply enough power to keep the computer alive).
Does anyone have any practical experience at powering their laptops through Empower and does anyone have any recommendations for inverters that I might want to consider buying?
#897379 by Syrome
02 Mar 2015, 20:10
If it won't charge the issue is most likely the wattage that the port on the airplane provides. This likely can't be corrected in a safe manner by an interver or voltage converter.
I would suggest purchasing an external battery that you can pre charge beforehand, plug your MacBook charger into, and drain as a battery. You can get ones with multiple ports to charge your phone as well via USB. I have one for my newest Ultrabook. Adds more juice than the built in battery.
#897383 by slinky09
02 Mar 2015, 20:50
I use Empower on the A346s and 747s all the time with my MacBook Air - I do even get a slow charge. Does the Pro require that much more oomph?
#897385 by Eggtastico
02 Mar 2015, 21:14
slinky09 wrote:I use Empower on the A346s and 747s all the time with my MacBook Air - I do even get a slow charge. Does the Pro require that much more oomph?
big difference in power between a macbook air & macbook pro
#897407 by Syrome
03 Mar 2015, 01:45
There's another idea though. You could buy the 45W MacBook Air charger and use that. It does indeed power a MacBook Pro and while it may be not recommended for the battery and might not even keep you in the positive range of charge, it would be better than nothing.
#897425 by sungod
03 Mar 2015, 09:56
even a lower power charger will still get some power into the mbp, which can extend runtime considerably
turn off unneeded features (bluetooth, wifi), configure energy saving, close applications you're not using and avoid doing things that need a lot of oomph
#897437 by Kraken
03 Mar 2015, 12:13
sungod wrote:turn off unneeded features (bluetooth, wifi), configure energy saving, close applications you're not using and avoid doing things that need a lot of oomph
Also dim the display backlight - that makes a huge difference to power consumption. My Macbook Air is perfectly useable with the screen backlight on 50%.
Whilst I always have my MagSafe / EmPower [depending on aircraft] adapter with me, I've never needed to plug it in in-flight yet as the battery like on the Macbook Air is so good.
#898158 by hmvs_dog
09 Mar 2015, 17:52
Thanks for everyone's help. I now need to weigh up whether I buy an Empower adapter or try and borrow one. Am I right in thinking that they aren't regularly carried on board by Virgin?
#898163 by chumba
09 Mar 2015, 18:31
Ive used my empower with a macbook pro before and it worked fine on VS.
If i can find it (haven't used it for a while) you're welcome to borrow it.
#898168 by hmvs_dog
09 Mar 2015, 18:50
Thanks for the lending offer Chumba, but I think it may be more practical for me to buy one. I've just had a conversation with Apple who confirm they don't make a suitable adapter for my model of MBP, but I can use a older one and buy a Magsafe to Magsafe2 converter.
How nice of them!
#898169 by mitchja
09 Mar 2015, 19:09
When I moved from a MacBook to my MacBook Air, I did just that and purchased the magsafe2 adapter which stays attached to my Apple EmPower airline power cable.
#898285 by Syrome
11 Mar 2015, 00:48
hmvs_dog wrote:Thanks for everyone's help. I now need to weigh up whether I buy an Empower adapter or try and borrow one. Am I right in thinking that they aren't regularly carried on board by Virgin?
They sometimes carry them, but then even more often than not they don't work.
