#899806 by trusse03
31 Mar 2015, 19:39
Looking at booking flights to Philadelphia from Manchester next September with a combination of Virgin Atlantic and Delta.
So rang up today and quoted £740 per person, when I go on expedia I can find the same flights for £665 per person.
Is this common? Should I trust booking with expedia or is it better to book direct?
Would I still earn miles if I book with expedia?
If it makes a difference - the expedia search shows the fares as (N) for Virgin Atlantic and (X) for the delta leg.
Sorry for all the questions, but hoping you dedicated fliers can help me out.
#899807 by Blacky1
31 Mar 2015, 20:04
Expedia is quite a common route for bookings with many vflyers doing the old ex EU trick so yes it can be trusted ,just remember to add your FF number to the booking to claim your miles etc
#899808 by griffinm7
31 Mar 2015, 20:27
Just a word of advice if you book your flight and include a middle name. I recently booked flights via Expedia and then found I couldn't log into my booking on the Virgin website.
After a call to Virgin customer services, I discovered that Expedia process your booking with your first and middle names together. For example, MikeJames Lee instead of Mike James Lee.
So if you've used a middle name and go to log into the Virgin website, remember to type your first and middle names as one.
Apparently Expedia always do this, although it's totally acceptable and won't cause a problem with your booking.
#899814 by RyanJW
31 Mar 2015, 21:27
griffinm7 wrote:For example, MikeJames Lee instead of Mike James Lee.
It also messes with your FC account when posting miles and tier points. It's been on and off for me but the last few times I've had to ring up post flight and get someone at the call centre to post the miles and tier points to my account.
Have fun!
#899817 by robinnelson
31 Mar 2015, 21:50
I normally use expedia as it can often be cheaper, very good if you want to book flight & hotel together. No charge for credit card and if you book using Quidco get 1% cashback on flights.
#899898 by AlphaEcho
01 Apr 2015, 22:05
robinnelson wrote:No charge for credit card and if you book using Quidco get 1% cashback on flights.
y) saved quite a bit on credit card charges, didn't realise beforehand, but did get a separate £20 charge on my credit card from Expedia, not sure what for, but the Quidco earning offset that. But still less than VS would have charged for a LHR-SFO UC return. Annoying when VS charge you for using one of their cards on their airline when you book direct. v(
#899930 by DoomWolf
02 Apr 2015, 09:37
It seems Expedia put their own charge separately from the airline cost on the credit card, although the total (airline + Expedia) should still be what was shown on screen when you completed the booking. For my flights, the Expedia booking confirmation shows £1313.09 for each ticket, but the credit card shows £1303.09 to VS for each ticket, plus £20 to Expedia.
#899986 by AlphaEcho
02 Apr 2015, 21:32
DoomWolf wrote:It seems Expedia put their own charge separately from the airline cost on the credit card, although the total (airline + Expedia) should still be what was shown on screen when you completed the booking. For my flights, the Expedia booking confirmation shows £1313.09 for each ticket, but the credit card shows £1303.09 to VS for each ticket, plus £20 to Expedia.
As you say the total amount I paid is what was quoted on the website, just when I checked my credit card it showed up with the separate £20 to Expedia.
#900299 by trusse03
07 Apr 2015, 11:09
Just another question in relation to this - the flights are coming up with a 1hr 27min layover in Atlanta, is that enough time to connect flights at Atlanta? Seems a bit risky?
#900301 by SlimpyJones
07 Apr 2015, 11:48
Trusse - it should be. I had a 1h 30m connection at ATL this weekend, and despite the immigration and customs lines being huge (the worst it had ever been according to those around me) I still made it through. Just though, it did involve a bit of running...
If you're going out of the US I'd say it's even more likely that you should be okay.
On a side note - has anyone else encountered an error when trying to book via Expedia? I'm trying to book the following itinerary:
Outbound:
VS109 MAN-ATL 01/05/2015
VS4568 ATL-ORD 01/05/2015
Return:
VS4632 ORD-JFK 03/05/2015
VS10 JFK-LHR 03/05/2015
The option is available on Expedia at £1,024 for PE which seems like a solid deal to me as on VS it's coming up at around £1,205. However each time I try to proceed I get an unknown error...
#900366 by stevebrass
07 Apr 2015, 20:15
When you book via Expedia do you get the flight booking reference so you can manage the booking via the VS website?
Users browsing this forum: No registered users and 176 guests
