#906625 by etk
05 Jul 2015, 08:46
Morning all!
We're flying out of Manchester on Thursday and just wondered if anyone knew if we'd be able to check in quite early.
Our travelling companions will be getting to the airport about 8am. I'm guessing VS will have check in desks open then as the MCO flight leaves at 1100, but will they let us check in for our LAS flight which leaves at 1235? We're flying in UC if that makes any difference.
#906626 by Florida White
05 Jul 2015, 09:26
Check in will be open at 7ish so you will have no problem and they will let you check in. You tend to get a bit of a rush around 8-9 for the VS75 and that's about it. We always stay at the Radisson and head down around 2 1/2 hours before and never had an issue. 8 will give you a leisurely start breakfast bit of duty free then chill in the lounge. Just a side note we've just come back and perfumes and aftershave are cheaper in duty free here than across the pond.
#906648 by Smid
05 Jul 2015, 12:38
If you are using the lounge, via Priority pass, or if Upper. They might well restrict access to that to three hours before, perhaps two. Our flight in Cancun was delayed two hours and we got refused the lounge for being techically too early, which was a bit of a git really...
