#908496 by Katcool
12 Aug 2015, 15:34
I have miles + money flights to MCO booked in PE. If UC seats become available would it be possible to upgrade the seats using miles? I'm pretty certain I can't upgrade the return leg as it's a K class but the outward leg is S.
Thanks.
#908513 by stuart_f
12 Aug 2015, 20:51
You could always ring Flying Club and ask for a quote to change the K fare to the S bucket then use miles to upgrade it assuming there's G availability. Sometimes the cost is quite modest.
#908514 by tontybear
12 Aug 2015, 20:58
ISTBC but aren't the rules for upgrading an M+M money different from other cash or reward flights?
#908516 by MoJoJo
12 Aug 2015, 21:41
tontybear wrote:ISTBC but aren't the rules for upgrading an M+M money different from other cash or reward flights?
I thought you could only upgrade MPM with the cash and miles difference between the cabins so not as simple as just the miles to upgrade to a G. An MPM fare is (I believe) where the miles give you a discount against the fare in the cabin you choose so it would make sense you cannot simply use more miles to upgrade to the next cabin
#908518 by tontybear
12 Aug 2015, 22:10
Yes that's what I thought.
#908520 by mikethe3rd
12 Aug 2015, 22:24
Can you get a MPM S fare code?
And it's 12,500 miles for a one way PE-UC upgrade or 25,000 for the return on the MCO route FYI.
#908529 by Neil
13 Aug 2015, 10:17
mikethe3rd wrote:Can you get a MPM S fare code?
No you can't.
To clarify, a MPM fare can only be upgrade with cash but not miles.
