#909813 by pem
11 Sep 2015, 08:04
Hi all
I am flying PE into Miami on VS005 it is scheduled to be an A340-600
Do PE exit the plane via the exit behind the PE row 23 seats or in between the PE and upper class ?
Can anyone advise what the immigration queues are like now - my previous arrivals on this route have been a nightmare due to long queues and slow processing
Do they let you use the APC kiosks ? as I am eligible due to having entered the USA via Orlando 9 months ago
do the APC kiosks speed entry much ?
thanks
#909814 by CHill710
11 Sep 2015, 08:33
I can't answer your question on immigration but I can say that you will board and leave by door 2 between upper and PE as the exit behind PE on the A340-600 is the over wing exit.
#909831 by gumshoe
11 Sep 2015, 12:27
If you've already used your ESTA to enter the U.S. at least once then yes, you should be able to use the kiosks.
As to whether they save time - how long is a piece of string. You'll have to weigh up the queues on the day. Just bear in mind once you've used the machine you have to take the bit of paper it spits out to a CBP agent anyway, so you'll almost certainly have to queue one way or another.
Not to mention the fact that the longest queues these days at US airports tend to be for customs, which affects everyone regardless of which immigration channel they used.
