#911254 by d4rr3ll
08 Oct 2015, 08:26
Hi All!
First post so be gentle if this is an obvious question.
We are flying from MAN>ORL on November on VS075, coming back on VS076. I can't seem to figure out which seat power will be available as I can't find the Aircraft reg for our flight. The lookup is here : http://www.virgin-atlantic.com/gb/en/th ... power.html
Would someone be able to point me in the right direction please.
Darrell
Edit to thread title by mod from ORL to MCO to avoid confusion............. Nick
#911258 by SlimpyJones
08 Oct 2015, 10:01
Hello, welcome to V-Flyer :)
For that route you're likely to be on either one of the LGW 747s or an A330-300. The particular aircraft (and hence aircraft registration) won't be disclosed until the day of the flight (so it seems somewhat daft of them to list it by aircraft reg, but that's besides the point).
On the page you linked, the LGW based 747s are in the second row. So if you end up in one of those, it'll be AC Power/USB for Premium Economy. Same for the A330s if you're in one of them. :)
#911283 by d4rr3ll
08 Oct 2015, 18:35
Thanks for the info. And apologies to Nick for the incorrect airport code, thanks for fixing.
I've had a look round the site a bit more now and found this :
toolbox_which_aircraft.php?flight=VS075
This appears to show the route is nearly 99% LGW-1, so a strong chance it'll be USB power I guess.
Incidentally I found some broken links on the site while I was browsing around, so from this page :
toolbox_aircraft_database.php?acReg=G-VROM
The links in the 'Flight' column point to :
which-aircraft.php?flight=VS085
When they should point to :
Is there a Mod around that can let somebody know?
Darrell
