#911840 by LucyLu
19 Oct 2015, 12:56
I just noticed on my FC account that I have been given a companion reward, but not an upgrade to PE reward........do they come through onto your FC account at separate times? (I assume you get both if you spend >£15k on your white card? I hope so as I am unlikely to use the companion one but will pprobably use the PE upgrade)
#911845 by Bretty
19 Oct 2015, 14:29
The companion voucher, which is useless unless you buy flexible tickets in the highest fare buckets, will post as soon as you hit the spend target. The PE vouchers post annually on the anniversary of the account opening.
#911865 by LucyLu
19 Oct 2015, 22:39
Ah thanks that makes sense, just that the two dates are close to one another in my case. I've never seen the point of the companion vouchers because the flight you have to buy is so expensive. I might, however get use from the PE voucher. In fact we used my partner's to upgrade one way each for our trip to BGI next year
