#912772 by archie
08 Nov 2015, 17:31
hi, I'm flying to Atlanta with virgin and then connecting to fort myers with delta on a single booking.
the virgin website does not show the delta part of the booking on my future flights,is this normal?
where can I find the delta booking reference so I can check the delta website for peace of mind or last minute changes?
thanks in advance
#912775 by SlimpyJones
08 Nov 2015, 18:27
Hi archie,
If the connection is booked under the same ticket, it *should* show under the Your Flights section at the top of the booking. If not - I'd give flying club a quick call, or double check your e-Ticket to check that it's definitely there. Note that the Future Flights page will only show the first sector of the booking (so VS103 London (LHR) to Atlanta (ATL)), you have to click on it to view the whole itinerary.
As far as checking the booking on Delta, you can use your Virgin booking reference to access it. Delta will have given it it's own number, but both work fine for looking it up on the Delta website. The Delta booking number will appear when you view the booking on the Delta website. :)
Hope this helps!
