#918096 by markyl
29 Feb 2016, 12:53
Gatwick airport has been closed to all flights due to an oil spillage on the runway ... which reportedly came from a Virgin jet...
http://www.standard.co.uk/news/transport/flights-halted-at-gatwick-airport-due-to-oil-spill-on-runway-a3191576.html
#918103 by mattyp
29 Feb 2016, 15:47
A lot of diversions though.
Mainly to SOU, BOH and STN although a couple got diverted to LHR including the EK15 which is now estimated to depart 5 hours late for the return 16.
I wouldn't fancy having to sort out a whole A380 worth of passengers who have missed connections at DXB :-O
#918114 by Donkeh
29 Feb 2016, 22:54
mikethe3rd wrote:
Donkeh wrote:Why wouldn't they move operations to the other runway?
They did.
Donkeh wrote:What happened to the Virgin jet which lost all of the oil?
As far as I'm aware it was G-VAST and still on the ground at Gatwick.
Thanks Mike. I don't really understand the news story, if they did move to the other runway?
Ok - so it was a landing jet - rather than one which was taking off. Makes more sense.
#918115 by mikethe3rd
29 Feb 2016, 23:01
Yeah, it was the Vegas inbound.
The airport closed for 80 minutes which was obviously enough to delay a number of outbound flights and cause a number of inbound to divert, hence the news story. When the airport reopened they were using the northern runway. I'd assume it couldn't be an instant switch due to aircraft positions on the ground along with assessing what had actually happened.
#918122 by Blacky1
01 Mar 2016, 05:44
mikethe3rd wrote:
Blacky1 wrote:Other runway ?
8L / 26R. Normal operations are 8R and 26L.
It took time to move all the aircraft from 8L / 26R as that doubles up as a taxiway for 8R / 26L, hence the closure.
Thanks for explaining Mike
#918128 by International Hitman
01 Mar 2016, 09:34
Other runway ?
Blacky, Gatwick actually has two runways but they are too close together to be used simultaneously, so the second runway [northern] can only used when the main runaway is out of use, the northern runway was originally constructed as a taxiway but has been upgraded/extended etc to a reserve runway howeverlacks instrument landing systems etc
#918130 by Blacky1
01 Mar 2016, 09:53
Other runway ?
I must admit I was a bit confused
Users browsing this forum: No registered users and 31 guests
