#919252 by eugegall
27 Mar 2016, 20:13
sungod wrote:yes, you can also take them into the CH as a guest
Thanks but does that mean Upper Class Check In and Priority security too?
#919272 by Kraken
28 Mar 2016, 15:22
Does anyone know if this works at Manchester also? Only asking as in November I am in UC & a friend is in PE on the same flight. I know the check-in side of things should be OK as the Swissport staff should, in theory, allow it. It's the security Fastrack that I am wondering about, as entrance to the Fastrack lane at MAN T2 requires you to scan your boarding pass barcode to get through the barrier. The computer will clearly say yes to an UC barcode, but I suspect no to a PE one.
I know once airside the Escape lounge access for the guest is no problem - have done it before. The lounge dragon did hesitate until I said i was happy to wait while she called someone from VS to check - they relented almost straight away.
