#921298 by whitey012001
14 May 2016, 09:22
I'm flying to Mexico from Gatwick in a couple of weeks. Just brought some Bose noise cancelling headphones but they didn't come with the 2 pin airplane socket.
On virgin PE do I need the 2 pin connector?
Thanks in advance
#921349 by dickydotcom
15 May 2016, 08:28
MoJoJo wrote:No, I just plug in to the one my Bose fits. You can however buy the two pin adaptor
I don't understand. I don't have Bose but do have a head set which comes with a one pin lead. I also have a two pin adapter with both pins of equal size, but my recollection of the Gatwick 747 is that the supplied headphones have two pins of different sizes.
Are you saying you just plug in the one pin lead into one socket?
Dick D
#921360 by MoJoJo
15 May 2016, 10:22
One pin is a different size. I just plug into the one the headphones fit into to. Check the online website for retail therapy as I think they sell an adaptor if you want one
#921361 by dickydotcom
15 May 2016, 11:06
MoJoJo wrote:One pin is a different size. I just plug into the one the headphones fit into to. Check the online website for retail therapy as I think they sell an adaptor if you want one
thanks,
Dick D
#921363 by mitchja
15 May 2016, 12:21
The second smaller socket is used to power the (very basic) noise canceling system for the headphones supplied in the Upper Class cabin.
You don't need a double pin headphones adapter if you plan on using your own headphones on any VS aircraft in any cabin.
The double pin system was only ever used on older IFE systems where the left and right channels where supplied separately using 2 sockets.
