#921338 by Wilbs
14 May 2016, 21:38
Hi this is my first post.
I am flying LHR - ATL - TPA in June UC and using DTCI, this is the first time that I have done this route and would be grateful if someone could answer a few questions.
Do I need to do OLCI for the Virgin & Delta flight or will VS take care of this at the DTCI ?
How easy is the connection through Atlanta as VS have only allowed us 1 hr 25 :-(
Many thanks
Wilbs
#921339 by SlimpyJones
14 May 2016, 22:15
Hello and welcome to the forum!
There's no real need to do OLCI - but it certainly couldn't hurt. You'll get the boarding passes for both when you arrive :)
ATL is a very easy airport to navigate through. There is a shuttle between the terminals that is very quick. 1h 25m should be just about do-able, but it is cutting it a little tight. If there's much of a delay arriving into ATL you may struggle. Besides the arrival time, the second biggest factor will be the immigration line, which really is anyone's guess. Is this your first time on your current ESTA? Will you be having checked baggage also? Remember that you'll need to pick up any checked luggage after clearing immigration, go through customs, recheck your luggage with Delta, go through security again and head to your gate. It can be a little cumbersome.
If it's any piece of mind though, there are a LOT of Delta services between ATL and TPA, on the random date I searched for they were leaving every hour. So if you do happen to misconnect, There's many many more they can put you on. But hopefully that won't be necessary. :)
#921340 by Wilbs
14 May 2016, 22:25
Hi Slimpyjones
Thank you for your reply. This isn't our first trip to the US, so hoping to use Immigration machines. So do we have to go to Delta check in or is there a connection desk as you come out of immigration?
#921347 by David
15 May 2016, 08:13
I used the ATL route last year (have a search for some TR's) and found it extremely easy - It was the 1st ATL flight out of LHR and we arrived into am empty immigration hall. The transfer after that was extremely simple.
Edit to add link viewtopic.php?f=4&t=290968
#921353 by SlimpyJones
15 May 2016, 09:26
Yes Wilbs there is a connection desk pretty much right in front of you after you exit customs where you can drop your bags off :)
#921355 by Rich85
15 May 2016, 09:49
I use ATL a lot to connect now VS go in there and initially left at least 2 hours between flights. Has always been so quick to get through that I accept minimum connections now. Especially if you are on an ESTA that you have previously used - it's then automated in ATL.
#921357 by CHill710
15 May 2016, 10:06
As you leave customs in ATL turn left and there is a belt to drop your bag on on the left. Then just go through security and on to the train to whichever concourse your next flight departs from.
#921362 by Wilbs
15 May 2016, 11:38
Thanks everyone , hopefully it will be go to plan :-) Looking forward to the CH first time at LHR :cool:
