#926315 by ghtconc
17 Sep 2016, 21:32
I heard a rumour that VS FF numbers were all going to be changed in October 16 such that you maintain the same FF number for life rather than the FF number being changed every time you change tier levels.
Is this correct?
#926316 by Hamster
17 Sep 2016, 23:16
Makes sense as they bring online the Delta IT systems.
#926318 by tontybear
18 Sep 2016, 02:37
ghtconc wrote:I heard a rumour that VS FF numbers were all going to be changed in October 16 such that you maintain the same FF number for life rather than the FF number being changed every time you change tier levels.
Is this correct?
well that depends on the source of the rumour.
whilst it does make sense it is a total change in current VS practice.
#926334 by joeyc
18 Sep 2016, 16:50
Does this rumour mean that all issued FC numbers are changing or will a new series be started for new joiners?
What's the source?
#926422 by jayden
20 Sep 2016, 23:21
I heard this back in Feb to from a senior customer relations rep when I wrote in regarding my problems with booking system.
#926433 by JCBR
21 Sep 2016, 10:59
ghtconc wrote:My VS source hasn't got a good track record with me, sorry
Must be the same source Daily Mail uses !
#926435 by Seyre1972
21 Sep 2016, 12:29
Think this thread had some detail VS111 to VS137
Only reason I found out was I'm also booked on VS137, with an onwards connecting flight - so wanted to check flight averages (takeoff/landing/delay etc). And couldn't find it listed anywhere. Whereas current VS111 is exact same route/timings ......
I've got 4 hrs between flights so hopefully not cutting it too fine .... (earlier flight would have meant less time in the LHR Clubhouse. :D :D :D )
Seyre1972
