#929421 by Traveller2
27 Nov 2016, 16:14
I believe so from the posts I have read on here about it. What a pain!
#929422 by MoJoJo
27 Nov 2016, 16:19
You can add it to your FC profile and it's supposed to get added to your booking to save time at OLCI
#929436 by horburyflyer
27 Nov 2016, 18:34
You can add your passport info to your FC profile. If traveling to the U.S. where the authorities need to know the address of your first night, this can now only be added during online check in or by the agent when you check in at the airport.....
Jon
#929460 by joeyc
27 Nov 2016, 23:45
horburyflyer wrote:You can add your passport info to your FC profile. If traveling to the U.S. where the authorities need to know the address of your first night, this can now only be added during online check in or by the agent when you check in at the airport.....
Jon
Is it sticking in your profile Jon? My passport and any APIS info for upcoming flights doesn't save after logout from FC at the moment.
#929463 by mitchja
28 Nov 2016, 00:17
All the info (passport number, Secure flight info, Redress & KPN etc) have all saved correctly here for me in my Flying Club profile.
It was also all pulled through correctly to a new booking I made online on Friday as well, well apart the passport number not been included as already mentioned though.
#929471 by Silver Fox
28 Nov 2016, 09:49
The one thing that does not stick for me is the hotel/first night's stay information. The redress number you have to put 0 or 00, then it will accept the KTN was my experience. I also do not like the fact that it has lost my middle name and I am unable to add it without, presumably, a call to FC which I want to avoid like the plague. I cannot recall if that is something I can override at OLCI either, or if it can be done at OLCI with this new rigourously tested piece of software.
#929492 by DoomWolf
28 Nov 2016, 12:45
The first night's stay info never saves. There's actually an error message that appears just above the section after you click save. The same function on Delta's manage booking page for DL flights (presumably using the same software) works perfectly and the information saves correctly.
