#2946 by colmc
14 Oct 2004, 23:58
When checking in online, is there any paperwork to print out at the end?
Am on VS 045 on Saturday and it would be nice to have checked in beforehand as it's an early flight..but alas, I've no printer hooked up to my home PC.
Any help appreciated!
Colm ;o)
#43333 by mitchja
15 Oct 2004, 00:05
no - you do get an email confirmation but you dont have to take it to the airport with you.
#43334 by colmc
15 Oct 2004, 00:06
Excellent..thanks very much for that. TR will be up when I return!
#43335 by declansmith
15 Oct 2004, 00:36
But when you get to the airport you will need to have some itinearay or something with you or elseyou wont be able to get pass the security agent who has to give you a sticker on your passport before you can get to the DIY check in desks!
So if you have nothing with you then you will need to get a print out from the ticket desk.
#43350 by Howard Long
15 Oct 2004, 11:18
This is an interesting point, and one I've pondered over for some time. For example on Sunday on my way back from IAD, I checked in online about 8 hours before the flight and the a/c was showing as an A346 UCS. Pretty much all I could do was select my seat, but then I could do this by updating my booking if more than 24 hours in advance.
I had no baggage to check, but I still had to go to the check-in desk to get a boarding card to clear security.
In the end it was a waste of time even selecting a seat: the a/c switched from a UCS A346 to a j2000 A343. Frustratingly the check in agent at first said nothing about changing my seat (from the nice tucked away A346 UCS 2K to the A343 J2000 5K wihin whispering distance of the bar and massage areas). It was only when I asked why it had been changed that I discovered the a/c change! Still, I shouldn't complain - it was a freebie FF ticket after all ;-)
So what is the point of checking in on line?
In comparison, BA have had the ability to check in online for some time, but it is only quite recently you've been able to print your own boarding pass when departing from some airports - for example http://www.howardlong.com/BABoardingPass.pdf, where you present the security agent with the pass and your photo id, and s/he has a handheld scanner device.
Cheers, Howard
#43380 by colmc
15 Oct 2004, 15:35
I do have my itinery/e-ticket printed off...but it sounds like a lot of hassle. I'll just have to get up an hour earlier tomorrow [:(]
#43395 by declansmith
15 Oct 2004, 18:42
I would say check in online, then you can pick your own seat.
Take your e-ticket to the DIY check in and just get your boarding pass printed.
#43444 by colmc
16 Oct 2004, 21:08
Hello from NY :)
I deided to use DIY check in..it worked out quite well, and only one person ahead of me in the bag-drop queue at LHR.
#43512 by largerjt
18 Oct 2004, 11:22
sorry if this has been asked before but i'm new....
when you check in on-line can you select exit/bulk head seats or are these still held for the airport check in?
many thanks
#43522 by Jonathan
18 Oct 2004, 12:42
These are held I think as VS charge for them on some routes
