Is the aircraft operating BFS-MCO-BFS a MAN based aircraft?
The BFS service is usually operated using a LGW/MAN 744 isn’t it? If so, it won’t be impacted by the new A332 aircraft.
When direct flights are not operating, the BFS service uses FlyBe connections to/from MAN.
All MAN>MCO flights should also still be operated using a 744 A/C as well so again won’t be impacted with the new A332’s.
