#943407 by coolflyer
08 May 2018, 12:58
Hello,
Would someone kindly be able to do a load check for VS41 to SFO on Friday (11th May)?
I've noticed that this flight has recently changed to an A340 from a 787 (which I am very disappointed about!) is there any chance this will be changed back to a 787 last minute?
Lastly, is it possible to log in and out of wifi on different devices on VS? E.g. if I connect on my phone can I then connect on my laptop later on in the flight?
Thank you!!
#943409 by gumshoe
08 May 2018, 13:22
Anything can happen on the day but I’d say it’s very, very unlikely that it’ll change back now. VS, in common with many airlines, has had to ground some of its Dreamliners because of faults with the Rolls Royce engines so older aircraft are being leased or brought back from retirement to cover.
Don’t know about the WiFi, sorry. (And be aware there may not even BE WiFi if it’s one of the old A340s that’s been brought back from the graveyard)
#943412 by mitchja
08 May 2018, 13:38
Thank you!!
Yes, can you use the WiFi on multiple devices. When setting up the service for the very first time, it will ask you to set-up a username and password. You then then simply log in to the system on the devices using those details.
#943416 by David
08 May 2018, 15:20
VS 41 LHR 11/05/18 1:10 PM
SFO 11/05/18 4:20 PM
346
Su,F
84% / 31m
J9 C9 D9 I9 Z5 W9 S9 H9 K7 Y9 B9 R9 L9 U9 M9 E9 Q9 X9 N0 O0 V9 T9
346
84% / 31m
Premium Economy - Award P Yes
Upper Class - Award G Yes
#943419 by coolflyer
08 May 2018, 16:08
David wrote:VS 41 LHR 11/05/18 1:10 PM
346
Su,F
84% / 31m
346
84% / 31m
Thanks for sending this over David - so am I right in thinking this looks like a fairly empty flight?
#943422 by gumshoe
08 May 2018, 16:54
Not empty, as the Z and K buckets aren’t showing 9s. But certainly not full.
Anything can change on the day though. Seemingly quiet UC & PE cabins can leave full if there are a lot of staff travelling on standby, for example.
