I see there are two packages for WiFi in the 787. The larger being 150 meg. I realise it’s extortionately expensively. However if I run out is it possible to buy another 150meg?
Yes, when I last used it on VS207, I used up the 150 very quickly and bought another a few times over (getting important work done!). It worked a little like when you buy roaming data on your phone... use it up and it runs out, for you to be presented with the buy data screen again.
Fly's a little too much.
