#944299 by jr17
10 Jun 2018, 19:40
Hey guys,
We’re flying on one of the newly refitted A330-300 from LHR - MIA in August.
Looking at paying the £14.99 for the inflight WiFi. Sitting in upper so will make use of it as I’ll have my laptop at easy access.
What are your experiences with the WiFi on this aircraft? Talking mainly about the speeds etc?
Cheers!
#944300 by mitchja
10 Jun 2018, 20:22
It's more than adequate for general web browsing, email & messaging etc. I was getting in the region of 20Mbps download speeds when I last used it. It does depend on how many people are using it though. The more people using it, the slower it runs at.
Streaming services such at Netflix et.c are all blocked. WiFi calling (if your mobile network supports it) is also blocked.
#944306 by ColOrd
11 Jun 2018, 08:37
On the 346, which I believe is the same system - I was able to do a Facebook Live video with no issues whatsoever.
#944313 by SlimpyJones
11 Jun 2018, 13:09
The only time I've never been able to connect was on a return from Shanghai. All other times I've been able to connect, albeit with a couple of teething problems early in the flight when the system starts up.
#944314 by Kraken
11 Jun 2018, 13:13
The GoGo internet wifi on the 747's was more than fast enough for me to stream Youtube videos (in HD) and watch the entire Corrs at Landsdowne Road concert on YouTube without buffering. The stream takes a little longer to start than it would on a home broadband connection, but once it got going it was fine. BBC iPlayer also worked (via a VPN to get round the geographical block).
The only issue I had was the GoGo internet landing page would not load by itself when I started Safari. Just entering 1.1.1.1 in the address bar and pressing enter forces it to load.
#944317 by mitchja
11 Jun 2018, 15:01
I've used it several times so far on various TATL flights (both the B789 system and the A333 system which are slightly different) and never had any issues with it.
My next couple of flights will be on the A346's so I'll see what happens with those. B744 flights from/to MAN in Sept so that gives me the full range A/C I'll try it on.
